My set-up is;
PC with wired (RTL8111) and wireless (AX201) cards.
Device that has an "Streaming app" installed connects to
AP created on the PC.
# Creating AP (with NM = NetworkManager);
Code:systemctl status NetworkManagerCode:sudo iwconfigCode:nmcli -f WIFI-PROPERTIES.AP device show wlan0Code:nmcli d wifi hotspot ifname wlan0 ssid FireTV password MT8695DCode:nmcli con showCode:nmcli device wifi
# I would then install/run "Wireshark";
# Wireshark 4.4.3Code:sudo apt install -y wireshark
Code:wireshark --versionCode:sudo wireshark
Up to here, it's all good
and "http" traffic (its 2025 and there is still httpshows up in wireshark when selecting wlan0 .....
So consulting following info/guides:
https://web.archive.org/web/20190608092620/https://wiki.wireshark.org/SSL
https://wiki.wireshark.org/TLS
https://tlswg.org/sslkeylogfile/draft-ietf-tls-keylogfile.html
and
https://www.comparitech.com/net-admin/decrypt-ssl-with-wireshark/
Code:nano ~/.bashrcCode:export SSLKEYLOGFILE=~/Documents/Wireshark/ssl-key.logCtrl+Shift+PCode:echo $SSLKEYLOGFILE
- Protocols -> TLS:
-- TLS debug file:
-- (Pre)-Master-Secret log filename:Code:~/Documents/Wireshark/ssl-debug.log
and trying on HTTPS Website, but,Code:~/Documents/Wireshark/ssl-key.log
my "ssl-key.log" is empty ....
Code:dpkg -l | grep -i openssl ii libcurl4t64:amd64 8.11.1-1+b1 amd64 easy-to-use client-side URL transfer library (OpenSSL flavour) ii libgnutls-openssl27t64:amd64 3.8.8-2 amd64 GNU TLS library - OpenSSL wrapper ii libsrt1.5-openssl:amd64 1.5.4-1 amd64 Secure Reliable Transport UDP streaming library (OpenSSL flavour) ii libssh-4:amd64 0.11.1-1 amd64 tiny C SSH library (OpenSSL flavor) ii openssl 3.4.0-2 amd64 Secure Sockets Layer toolkit - cryptographic utility ii openssl-provider-legacy 3.4.0-2 amd64 Secure Sockets Layer toolkit - cryptographic utility ii perl-openssl-defaults:amd64 7+b2 amd64 version compatibility baseline for Perl OpenSSL packages ii ssl-cert 1.1.3 all simple debconf wrapper for OpenSSL
What I want to do,
is to have a look at what the "Streaming" app is sending/receiving via TLSv1.2/3 .....
And also via firefox and the "Streaming" website .....
Where did I go wrong?
Results 1 to 1 of 1
How to decrypt this?
By Manickam in forum Video Streaming DownloadingReplies: 9Last Post: 1st Dec 2024, 05:14 -
Help decrypt
By houjiangen in forum Video Streaming DownloadingReplies: 4Last Post: 14th Sep 2024, 20:11 -
[friDay Video] Max retries exceeded with url... (caused by SSL error)
By CrymanChen in forum Video Streaming DownloadingReplies: 13Last Post: 23rd Nov 2023, 10:47 -
Help decrypt mp4
By tomasrage in forum Video Streaming DownloadingReplies: 4Last Post: 20th Oct 2023, 06:25 -
Decrypt MPD
By Zaito in forum Video Streaming DownloadingReplies: 2Last Post: 3rd Sep 2022, 23:36
