Hi can someone tell me if u can copy a SVCD to VCD, i have the Easy CD Creator (Basic), is it just the same as copying normal cd's??
Thanks for any help
SVCD uses MPEG2 encoding, and VCD uses MPEG1 encoding, and EZ CD does not support SVCD, and the Basic doesn't support VCD either.
You need to first convert your MPEG2 to MPEG1, and then Author it using any popular program you want that supports VCD.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
