I bought a new tv a few weeks ago. Everything I need, but this guy doesn't support Dolby Vision.
I have a few movies only in DV, so playing them back gives a reddish picture.
On this TV, an AppleTV is connected. Playing back the movie files using Infuse Pro converts this real time to HDR10. One problem: the movie files also have Dolby Atmos on a TrueHD track. The ATV doesn't support TrueHD.
It would be nice if there's an app which can convert a Dolby Vision movie to a normal HDR10 file (without dynamic metadata) or even better HDR10+
Does someone has experience with this? And hopefully it exists on MacOS..
thanks!![]()
Chances are these videos are Dolby Vision pofile 5. It uses Dolby proprietary colorspace.
In case of profile 8 or 7, these already have a hdr base-layer to which a player can go back to. It shouldn't be necessary to take out the dynamic metadata as a non-compatible player would ignore it.
Can't help you with converting to HDR10+. -
You can be right. I remember a certain movie which indeed gave a Dolby Vision pop-up in my previous TV. Using the native app Plex on my actual TV, the picture is fine. In the picture settings there's a HDR mark. I previously thought this file has two kind of "layers". DV if possible, if not a fallback to normal HDR.
Maybe the newer DV movies always use profile 8 or 7, or is this completely rubbish? -
Thanks for the info. Time will tell.
Crazy there's no software to convert it, because AppleTV devices do it real time.
Convert mkv with Dolby Vision to UHD Bluray
By kallek in forum Authoring (Blu-ray)Replies: 19Last Post: 25th Apr 2024, 06:50 -
Converting HDR10+ to HDR (Plex doesn't properly support HDR10+)
By fireaza in forum Video ConversionReplies: 3Last Post: 18th Nov 2023, 05:35 -
Possible to convert HDR10 to HDR10+?
By ShikuTeshi in forum Video ConversionReplies: 8Last Post: 18th Jan 2022, 15:31 -
Dolby Vision
By JosephTocco in forum Newbie / General discussionsReplies: 15Last Post: 31st Oct 2021, 05:06 -
4K HDR10 > FHD HDR10 weights less than 4K HDR10 > FHD SDR ????
By bokeron2020 in forum Video ConversionReplies: 17Last Post: 17th Aug 2021, 21:47
