Hi ...
thanks
Could someone explain to me how I can prevent this error? so that for any loaded source there is never this errorCode:import("v:\FuzzyBorders.avsi") LoadPlugin("V:\BestSource.dll") BSVideoSource("V:\eampleBMP.BMP") blur = 100 gain = 0.9 blue = 0.2 noise = 3 sat = 0.5 GaussResize(1920, 1080, p=19) QGaussBlur(blur, blur).QGaussBlur(blur, blur) ColorYUV(gain_y=f2c(gain), off_u=blue, cont_u=f2c(sat), cont_v=f2c(sat)) AddGrain(Float(noise), 0.22, 0.22, constant=1>0) CONVERTTOYUY2(INTERLACED=FALSE)
[Attachment 85378 - Click to enlarge]
Bitmap images open as RGB. You need to convert to YUV before calling ColorYUV() or any other filter that requires YUV.
yes but, to convert to YUV is enough
the only
Code:ConvertToYUY2(interlaced=false)
Your ColorYUV() is also flawed.
So here your modified script:
Code:import("v:\FuzzyBorders.avsi") LoadPlugin("V:\BestSource.dll") BSVideoSource("V:\eampleBMP.BMP") blur = 100 gain = 0.9 blue = 0.2 noise = 3 sat = 0.5 GaussResize(1920, 1080, p=19) QGaussBlur(blur, blur).QGaussBlur(blur, blur) ConvertToYUY2(interlaced=false) #converting RGB to YUV ColorYUV(f2c=true, gain_y=gain, off_u=blue, cont_u=sat, cont_v=sat) AddGrain(Float(noise), 0.22, 0.22, constant=1>0)
BestSource.dll have to work in colorspace="YUY2"
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2025, 08:53 -
"code":400,"error":true,"message" on http://getwvkeys.cc
By johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 21:45 -
getwvkeys.cc code":400,"error":true,"message":"Failed to get license: 405
By Koldunas in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2023, 02:44 -
Extract Y/C in YUV Colorspace in AviSynth?
By musmodtos in forum Newbie / General discussionsReplies: 7Last Post: 26th May 2023, 18:47 -
AviSynth Script error: there is no function named "setmtmode"
By minimax in forum RestorationReplies: 27Last Post: 10th Sep 2021, 03:57
