In Selur Hybrid, one can select multiple video files to create a batch process. I have found that Hybrid will use the Input Scan Type of the first video file and use that Input Scan Type for all the subsequent video files in the batch.
For instance, if one adds a DV25 file (which is BFF) and then a HuffYUV files (which is TFF), Hybrid will use the BFF Input Scan Type for both videos, which will create visual issues for the HuffYUV video file when it is processed. (By the way, the files are properly flagged when they come into Hybrid, which I confirmed by processing each of them independently.)
I viewed all the settings in Hybrid, and I searched the various fourms, but I didn't find information on this issue.
Is there a setting in Hybrid that would force Hybrid to change the Input Scan Type for every video that is part of the batch and not assume the Input Scan Type is the same for all of them?
I understand that the workaround is to simply create a batch for video files of only the same type. Which is acceptable and probably the best practice anyway.
Sidenote only: HUFFYUV does not have a field order flag, so hybrid just uses the default BFF for HUFFYUV files. For HUFFYUF sources you have to set the correct field order (TFF or BFF) manually if you don't want it to be possibly wrong.
For field order setting never trust the tools anyway. -
If they are really flagged properly, share a debug output of the analysis of the files and the job creation.By the way, the files are properly flagged when they come into Hybrid, which I confirmed by processing each of them independently.users currently on my ignore list: deadrats, Stears555, marcorocchini
UPDATE: I made an error. The HuffYUV avi files are not detected as Top Field First (TFF) in Hybrid as I had assumed. My error stems from the fact that I normally check the box "Overwrite input scan to: top field first" in the Filtering--Deinterlace/Telecine screen. I know understand that the HuffYUV files are not flagged in the meta info as TFF.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2472Last Post: 7th May 2026, 12:58 -
QTGMC Batch Processing
By Jay123210599 in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2023, 09:09 -
Video files: Report list of media types with attributes?
By Frasier in forum ComputerReplies: 0Last Post: 18th Sep 2021, 21:42 -
Batch renaming of different video file types based on Windows Date
By B784 in forum ComputerReplies: 4Last Post: 27th Aug 2021, 13:59 -
Azure compute instance types for video processing & encoding
By Madhav in forum Video ConversionReplies: 0Last Post: 18th Jul 2021, 12:07
