Good night,
Sorry for the kinda vague title, but this is my first time messing with video at this level.
I have discovered a childhood series in DVD format, I riped it with makeMKV, and if I play it with MPC the image is horrible, its text book interlacing issue.
So I found this forum, read a bit here and there, and tried out Hybrid (just using random things) and the interlacing is gone, but can I also improve the video, maybe remove some of the grain, and make it a bit sharper, just know where to start from..
Interestingly enough, the interlacing issue doesn't show up on the Hybrid original image preview..
I tried to upload images and a cut 30 seconds video, but the popup stays forever in the Uploading File(s) - Please Wait message.
Image in MPV:
Image in hybrid:
	you should try re-uploading the video snippet,...
 (you could also upload it to mediafire or similar and share the link if for some reason uploading here does not work for you)
 You might also want to mention what gpu you use to let others know whether using machine learning filters is an option.users currently on my ignore list: deadrats, Stears555, marcorocchini
	Good evening Selur,
 I upload the cut video to mediafire:
 https://www.mediafire.com/file/wij11sf0h1403k5/video_cut.mkv
 I have an RTX 2070 with 8GB of VRAM, and an i7-9750H with 32GB of RAM.
 Thanks for your help.
	I thought your source is a DVD. The file you shared is H.264.
 ....Code:General Unique ID : 294879020170879421002260428034051980311 (0xDDD7A22C85E0A4977973141A1620BC17) Complete name : c:\Users\Selur\Desktop\video_cut.mkv Format : Matroska Format version : Version 4 File size : 12.6 MiB Duration : 30 s 3 ms Overall bit rate mode : Variable Overall bit rate : 3 536 kb/s Frame rate : 1 244.176 FPS Writing application : Lavf61.9.106 Writing library : Lavf61.9.106 ErrorDetectionType : Per level 1 Video ID : 1 ID in the original source medium : 224 (0xE0) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 30 s 3 ms Bit rate : 8 999 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Variable Frame rate : 1 244.176 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Original scan type : Progressive Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.017 Stream size : 1.56 GiB Writing library : x264 core 164 r3204 373697b Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : No Forced : No Color range : Limited Original source medium : DVD-Video Audio ID : 2 ID in the original source medium : 189 (0xBD)128 (0x80) Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 30 s 3 ms Bit rate mode : Variable Bit rate : 112 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Frame rate : 1 555.211 FPS (31 SPF) Compression mode : Lossy Delay relative to video : -3 ms Stream size : 34.2 MiB Title : Stereo Writing application : Lavc61.32.101 Writing library : libVorbis (Reducing Environment) (20200704 (Reducing Environment)) Language : Portuguese Default : Yes Forced : No Original source medium : DVD-Video Menu 00:00:00.080 : Chapter 01
 => Best use mkvtoolnix to cut the mkv you got from MakeMKV.
 Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
	Not sure whether the DVD source also has broken frames like your sample, or whether that happened during the DVD->(h.264, vorbis) conversion.
 But frames like:
 used: BasicVSR++ + 2x_BIGOLDIES. (2x-BIGOLDIES is probably too agressive)
 are not really reparable automatically.
 => Correction, seems like this is a problem that only occurs when using hardware decoding.
 With software decoding, it looks better:
 (I used TFM for the field matching to handle the combing artifacts)
 An unconverted sample from the MakeMKV output would still be better.
 Cu SelurLast edited by Selur; 8th Feb 2025 at 14:13. users currently on my ignore list: deadrats, Stears555, marcorocchini
	Sorry for the messed up file, I used ffmpeg to cut it, and didn't check if it transcoded the video or not.
 Here is the file, cut with MKVToolNix:
 https://www.mediafire.com/file/1bxaixckjy2pezr/A1_t00_%25281%2529-001.mkv/
 If it is not asking much, BasicVSR++ is this one?
 https://github.com/ckkelvinchan/BasicVSR_PlusPlus
 And for BIGOLDIES, do you use some sort or GUI (chaiNNer for example, since others are either paid, or not updated for some time)?
 Thank you for your time, and sorry to make such basic questions, but this is a whole world unknown to me, so many tools from various places seem to be used, its a bit overwhelming.
	I used Hybrid with the torch-addon to use BasicVSR++ and 2x-BIGOLDIES, note that I used 1x-ToonVHS in the file I attached before. Note that 1x-ToonVHS (should be renamed to 1x_ToonVHS when used in Hybrid) and some denoising is probably enough and BasicVSR++ might be overkill. (I mainly added it to combat some of the glitches I saw.)
 In Hybrid try:- "Filtering->Vapoursynth->Frame->Misc->TFM" (for the combing artifacts)
- "Filtering->Vapoursynth->Other->VSGAN" with the 1x_ToonVHS pth file. (also enable 'Fix Color')
- "Filtering->Vapoursynth->Denoise->KNLMeansCL" with 'Distance' 0 and Strength '5'
  Improving Quality of Video ClipBy meeshu in forum RestorationReplies: 4Last Post: 10th Mar 2024, 17:05
  Help with improving this video post QTGMC de-interlaceBy VideoYak in forum RestorationReplies: 36Last Post: 14th Sep 2023, 17:19
  Interlacing-like video glitchBy zeromido in forum Newbie / General discussionsReplies: 5Last Post: 18th Jul 2021, 12:50
  Help with de-interlacing a video.By Parhelion in forum Newbie / General discussionsReplies: 8Last Post: 19th Sep 2020, 17:35
  Improving laserdisc video transferBy Arnold_Layne in forum RestorationReplies: 13Last Post: 25th May 2020, 14:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
