need help in removing background noise from an audio file and make the conversation clear and loud the be heard and understand
by the way i'm not an expert .
Results 1 to 16 of 16
You'll have to post a sample, someone here may have some skills with what sounds like a forensic analysis
The first thing I would probably do is reduce the level of those very loud sounds which sound like someone touching or handling the microphone. There may be nothing that can be done to recover the speech under all that incredible noise. Then I'd raise the levels of the other sections where there is much less competing noise.
Man, that's bad audio. I can't understand a word of it but am inclined to think you have a good case for divorce. Here is a very quick, dirty go with a few tools in Audacity. Maybe it helps, maybe it doesn't...
https://files.videohelp.com/u/313119/Recording%2026-_AudioTrimmer.com_-%20RETURN.wavLast edited by Dooby; 9th Feb 2025 at 14:21.
Here's an attempt using Izotope RX and the DxRevive plugin -
I wouldn't call it particularly clear, but it's better than it was -
Removing artifacts distorts the important elements they wanted to keep (the speech). I never altered the noise for that reason, just boosted the volume in the quiet parts. Yours took work though, I'll give you that, making and remaking noise profiles takes time, time I wasn't prepared to spend.
I used a dialogue restoration plugin, which I named. It's a suggestion only. If the OP thinks
it has promise, he can download it and try it for himself -
It needs a little more polishing, but I think it's good enough:
https://files.videohelp.com/u/313119/Recording_26-AudioTrimmer.com-Final_Result.wav
Removing Background Sound?
By brispuss in forum AudioReplies: 18Last Post: 10th Mar 2025, 16:02 -
What free program offers change in audio background noise to highten volume
By Halobolt07 in forum AudioReplies: 2Last Post: 10th Feb 2025, 06:45 -
Tools for removing background audio buzzing sound from VHS transfer?
By Wanderer in forum AudioReplies: 32Last Post: 6th Nov 2024, 20:12 -
Clearing out background noise after using a stem splitter
By imkira3 in forum AudioReplies: 8Last Post: 17th Jun 2023, 02:24
