Hi there,
I have a bunch of hd files that i need to convert from H265 to H264, I need to convert losslessly. Can any member here advise on how to do this.
Peace
Results 1 to 22 of 22
“He who makes a beast of himself gets rid of the pain of being a man.”
Generally this is not possible - perhaps it could be done without converting video from transformation domain to raw video but AFAIK there is no ready to use product (and even it such product ever exist then it will be rather expensive - not for home user).
It's option to use with x264.exe.
Or you can use ffmpeg:
ffmpeg -i input265.mkv -c:v libx264 -preset medium-crf 0 -c:a copy output264.mkv -
Lossless encoding (mentioned "-q0") will not provide lossless conversion (transcoding) also if your source is normally encoded (i.e. average video) using "-q0" will elevate bitrate without any quality gain over source.
Use
This gives you a video that shows no loss of quality visually and produces a file size that is still acceptable.Code:ffmpeg -i input265.mkv -c:v libx264 -preset medium -crf 18 -c:a copy output264.mkv
There is no lossless re-encoding of an already compressed video (x265). -
I have used HandBrake and Shutter Encoder. I have not noticed any loss of quality. These two programs are free.
Nope but feel free to try and prove it - i will be happy to be wrong - you can use video compare feature (or subtract video from source and calculate delta) or even some dedicated video measurement like SSIM or generic PSNR. There is many ways to prove that there is no possible to losslessly transcode video from one lossy codec to another...
Good luck. -
Please stop spreading nonsense.
Thanks for all the interest guys.
This is where i am.
I have inherited a project file of an edit which is not quite finished. It is a DaVinci project.
The project was originally on a pc but moved to an external SSD.
I have relinked all of the files except a number of video files that were shot on a different camera. When i bring these into the media pool i only get audio.
The videographer suggested converting the files to H264 which i tested using VLC media player. Now when i add the video to the project i only get the video no audio.
I tried the files in Premiere pro. The H265 original only plays audio in Premiere Pro. After converting to H264 in VLC the file plays perfectly in Premiere Pro.
In VLC i used the option to convert to H264 MP3 in MP4.
So DaVinci plays only the the audio of the H265 and video only of the H264.
Anyone have any idea what could be going on?“He who makes a beast of himself gets rid of the pain of being a man.” -
IMHO export project as for example Prores+audio PCM and later convert it to H.265 and/or H.264 with audio codec you wish.
Perhaps, that's why i suggested to export your project in something like intermediate codec and rely on final encoding with working tool (i mean not so many people use DaVinci so you may face issue trying to solve some DaVinci misbehavior).
Sometimes it is easier to give up instead trying to solve tool hiccup. -
-qp 0 is a special lossless mode in x264. Many h.264 decoders can't decompress this so it may not be much use to the OP.
https://trac.ffmpeg.org/wiki/Encode/H.264#LosslessH.264
See the attached samples.
265.mkv is a short x265 encoded video
264.mkv is 265.mkv encoded with ffmpeg libx264 at -qp 0
_265_to_264 is the ffmpeg batch file used to do that encoding
_PSNR.BAT runs ffmpeg to compare 264.mkv to 265.mkv, shows PSNR = inf
_SSIM.BAT runts ffmpeg to compare 264.mkv to 265.mkv, show SSIM = 1.000000
diff.avs subtracts 264.mkv from 265.mkv to show there are no differences -
Master VoodooFX docet
The guy clearly is missing few bolts, just leave him alone with his nonsense posts.
H265 To H265 vs H264 to H265
By V1rg0_ in forum Newbie / General discussionsReplies: 4Last Post: 25th Apr 2022, 01:21 -
[FFmpeg+SvtAv1] convert a H264 or H265 1080p file to Av1 720p
By ignace72 in forum Video ConversionReplies: 11Last Post: 29th Mar 2022, 17:16 -
Plays H264, but not H265...
By taboo in forum Newbie / General discussionsReplies: 3Last Post: 23rd May 2021, 19:56 -
Going from 10Bit H265 to 8Bit H264
By carlmart in forum Video ConversionReplies: 12Last Post: 14th May 2021, 16:01 -
h264 to h265 doesn't reduce size
By Hahaha in forum Video ConversionReplies: 11Last Post: 6th May 2020, 04:33
