If you're using a Macbook as I am, and don't want to spend the 30 bucks to get Mac the Ripper, you may be tempted to try to use DVD Decrypter in a Windows virtual machine. It won't work.
During my many attempts to do so, DVD Decrypter always took quite long. So long in fact, I was (and still am) quite unsure if it would finish in my lifetime, or perhaps even within the lifespan of the universe itself. I spent ages tweaking the settings, trying to think of what was configured incorrectly.
Fast forward a month or two, and I had purchased an old Windows laptop for unrelated reasons; it had absolutely awful specifications, but worked as a webserver. One day, out of mere curiosity, I attempted to use DVD Decrypter on it.
What it took 3 hours to accomplish in the virtual machine (5% of the first file), the laptop accomplished in less than a minute.
(Although I specify DVD Decrypter in the title, I did try other ripping software during the VM testing period, they all had the same problems, which is strange, since VirtualBox is normally quite good at handling DVD drive passthrough)
				Results 1 to 9 of 9
	So what's the tip? Buy an old windows laptop?
 Seriously though, a FREE alternative of DVD Decrypter for us Mac users might be MakeMKV. I just found out MakeMKV can rip to ISO a few months back.
	I don't remember MakeMKV being a rip software, only a re-encode software.
 Note that "rip" has a very specific jargon meaning. You essentially take data from a container-less system, or an alternate file system (like UDF for DVD-Video), and store it in a containerized file like WAV, AVI, or ISO (BIN/CUE, etc). Re-encoding is not ripping.
 Too many people misuse the term.Want my help? Ask here! (not via PM!)
 FAQs: Best Blank Discs  Best TBCs  Best VCRs for capture  Restore VHS
	It doesn't alter the data,it's still a ripping software that gives you the exact video in another container.That's like saying mkvmerge alters the data by putting it in another container. I think,therefore i am a hamster.
	It's not true because the disc data is formatted to an authored standard (DVD-Video, BDAV/BDMV).
 Ripping must be bidirectional.
 - I can rip/transfer ("capture" is misnomer) a DV tape (extract non-containized DV data), saved into a AVI/MOV file. But then I can go the other way, easily write the file back to tape.
 - I can rip an audio CD to WAV/AIFF, burn it back to CD-R. (Very minimal changes happen, so it's only 99%+ to original.)
 - I can rip a CD/DVD/BD to ISO/image, and burn it back.
 When you use MKVMerge to remove an asset from within the disc formatting (DVD-Video, BDMV/BDAV, etc), it's lost. You lose menus, you lose structure. It cannot be burned back to an original media (recordable disc). That's the difference.
 "Rip" is a jargon that has been heavily misused over the years.
 People want to
 - "rip" (CAPTURE!) videotapes
 - "rip" (RE-ENCODE!) CD to MP3
 - "rip" (SELECTIVELY REMOVED DATA!) DVD/BD to AVI/MP4/MKV/whatever
 But it's more accurate to "rip a fart" than to "rip to MKV".Want my help? Ask here! (not via PM!)
	Would extract content be a more accurate description?
 Its not free, but I use Mac-DVDRipper-Pro
 Honestly, if you cant afford a few simple tools, you should probably wait until you can IMHO.Last edited by crjackson; 5th Mar 2025 at 23:20.
  Asking for a quick tip on this techniqueBy tomigoi in forum EditingReplies: 1Last Post: 29th May 2024, 09:27
  Tip - How to Capture with AJA Kona LHe PlusBy jwillis84 in forum Capturing and VCRReplies: 2Last Post: 19th Jan 2023, 10:08
  Any camcorder top handle tipBy realspeed in forum Newbie / General discussionsReplies: 0Last Post: 11th Oct 2022, 12:22
  Weird problem with DVD DecrypterBy ampersand in forum DVD RippingReplies: 2Last Post: 25th Dec 2020, 17:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
