how flip video without re encoding
like this
[Attachment 85305 - Click to enlarge]
Results 1 to 9 of 9
Assuming it's H.264: ffmpegs bitstream filter h264_metadata allows to signal that the video should be flipped horizontally on playback,...
users currently on my ignore list: deadrats, Stears555, marcorocchini -
https://ffmpeg.org/ffmpeg-bitstream-filters.html#hevc_005fmetadata => nope
Depending on the container you use, adding some flip horizontal metadata might be available, but fewer players will support it.
For mp4 video:
should work. (see: https://ffmpeg.org/ffmpeg-all.html#Video-Options)Code:ffmpeg -display_hflip -i "Path to source video" -c copy "path to flipped output.mp4"
I attached an example.
The mp4 is correctly flipped horizontally when played by Chrome or ffplay, but MPC-HC for example flips the video vertically instead.
(iirc. mov also has such a flag too)
If the flag is in the container, the video format itself should not matter assuming it's supported by the container, but the downside it, this has to be specifically supported by the media player.
Cu SelurLast edited by Selur; 4th Feb 2025 at 13:46. Reason: added missing space
Maybe. Don't know of anything more simple than calling a simple command line, but there might be a GUI which allows this and I simply don't know it.
@ simoo
AI Summary:
# True flipping always requires re-encoding
# Meta Data flipping flag update doesn't need a re-encode, but doesn't work for most players, containers, and codecs.
Concatenating while encoding clips from video A without encoding video B
By imkira3 in forum EditingReplies: 10Last Post: 9th Jun 2024, 06:24 -
I'm trying to find a way to flip/reverse all the letters
By danielDR in forum SubtitleReplies: 17Last Post: 14th Feb 2024, 16:32 -
how flip video in Hybrid software
By simoo in forum Video ConversionReplies: 11Last Post: 7th Nov 2023, 13:56 -
Panasonic AG-1960 Flip Down Panel Buttons Not Working
By companda in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2022, 00:23 -
How to convert .m2ts video to .mkv video without re-encoding by ffmpeg ?
By aaajan in forum Video ConversionReplies: 13Last Post: 27th Aug 2021, 08:30
