I have a JVC HR-3900U that has very few hours on it and it works great except for one fairly major problem. Occasionally when I stop a tape during playback and then after a little while press play again, the tape will wind multiple times around the drum and crinkle the tape. I then have to carefully remove the tape by hand from the deck. I don't have any issues with rewind or fast-forward, and if I just play the tape straight through without stops, everything works just fine. It's just when I play, hit stop, and then hit play again.
Any idea what might cause this? I've already thoroughly cleaned the tape path, including the pinch roller, and mechanically everything looks good. Heads are also sparkling clean.
Results 1 to 1 of 1
JVC HR-J668 VCR ejecting tapes
By Krazern in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2024, 12:36 -
S-VHS JVC VCR as comb filter passthrough for non S-VHS VCR?
By Krazern in forum Capturing and VCRReplies: 22Last Post: 6th May 2024, 07:18 -
VCR plays vhs tapes fine, but vhs-c tapes in an adapter stop after 2-3 sec.
By bobbooptop in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2022, 04:50 -
Audio Muffled on Certain Tapes on JVC but Sounds Fine on Other VCR
By bbmaster123 in forum Capturing and VCRReplies: 31Last Post: 20th Aug 2021, 07:27 -
How to Remove Text "VIDEO CALIBRATION" from VHS tapes (VCR=JVC HR-S7600U)
By timepassenger in forum Capturing and VCRReplies: 10Last Post: 28th Apr 2020, 14:09
