Salve ho un problema con N_m3u8DL in pratica se scarico un video su prime alla riproduzione riesco a vedere solo la pubblicità. il seguito del video é praticamente verde e chiaramente non viene riprodotto, ho tutto disponibile clear keys etc etc .... fino ad una settimana fa tutto era perfetto ..... quakcuno potrebbe aiutarmi ???
				Results 1 to 10 of 10
	Ads most likely need to be edited out. Video URL or full unedited n_m3u8dl-re command? --[----->+<]>.++++++++++++.---.--------.
	Ti posso incollare il link e le ck ma ho come l'impressione che le chiavi estratte siano sbagliate, potresti controllare per me grazie ?
 https://abf262xaaaaaaaamfiryr6vfp62ah.pop-it-cf.dash.pv-cdn.net/dm/3$0CiQIARIGCgRiSEhIICUwAUgBUgaAwAKB8AN6A4C4F4IBAQG IAQQYAQ/1@da0d9561b59434bb1750667e3055b4c6/78ea/c221/63aa/4535-b80d-4d9c9317c66e/eeb771c8-305e-465a-b345-29c6978cb581_corrected.mpd?custom=true&encoding=se gmentBase&amznDtid=AOAGZA014O5RE&encoding=segmentB ase
 --key 9e185e9ff89543d1a71c645868b2bc1d:a9308dff1ffc0f750 7a57bbe87281a38
	@powerbit
 this is english forum. please respect everybody here and talk in english
	Use
 https://forum.videohelp.com/threads/416316-%5BRelease%5D-WidevineProxy2-Extension-Bypa...s-Lic-wrapping
 or
 https://forum.videohelp.com/threads/416316-[Release]-WidevineProxy2-Extension-Bypass-H...e8#post2761978
 from some discord group, no idea which one. Best to just post the video URL so you can get the correct decryption keys from other people--[----->+<]>.++++++++++++.---.--------.
	no problem. it's just for respect to everyone here
 if you have more issue with your video, reply again
  Regarding downloading using (N_m3u8DL-RE)By khaledgamil in forum Video Streaming DownloadingReplies: 68Last Post: 17th Apr 2025, 13:39
  need help with N_m3u8dl-reBy monk87 in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Nov 2024, 06:58
  help with N_m3u8DL-REBy darwin567 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Oct 2024, 02:59
  Need help me getting the N_m3u8DL-REBy mrsimple8x in forum Video Streaming DownloadingReplies: 2Last Post: 19th Dec 2023, 08:29
  Problema con VideoRedo Tv Suite V6: Remove frame audioBy anet88 in forum EditingReplies: 1Last Post: 26th Jan 2023, 07:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
