I've ripped a DVD to edit the content later with Resolve. The videos are in MPEG format and I need to convert them to H.264. The MPEG video looks smooth, with no frame skips, but when I deinterlace it with HandBrake to convert it to H.264, it produces a judder effect. I have tried all the deinterlacing settings, but none have worked. Can anyone help me?
Here is the link to the file: https://mega.nz/file/nmQy2L6A#iCATcwdasqz0sBjIjKiTGbC_nwrluXy4jUaXUOjOJeI
Thank you!
Without downloading the file: Search everything written in the last several decades about video basics for "interlacing" or "Telecine"...
StainlessS translated a German guide by scharfis_brain into English. -
I'm quite sure that the original MPEG-2 video on DVD had an "interlaced" or "Soft Telecine" flag set, so the video decoder knows that it needs to display the decoded result field by field or with IVTC applied.
The copy in H.264 either did not have it set, so the decoder displays the encoded frames progesssively, causing combing or Telecine micro stutter, or maybe it is also interlaced but with the wrong field order, so the decoder displays a forth-and-back motion. -
It's a field blended conversion 23.976 to "PAL" 25fps
You cannot "fix" it with handbrake
You can improve it using a double rate deinterlacer + srestore in avisynth or vapoursynth
Beware that there are field order swap in the intro vs. the main segment. The intro and credits are BFF. Main content is TFF. You'd have to treat them differently and splice together . Also, parts of the intro (fades, text fades) and credits (with moving overlaid text) are true interlaced content - they run at 50 samples/sec. The problem is the credits will be "jerky" at 23.976p. And 23.976 is not evenly divisible into 50. I do not know if the credits are important for your project, but you cannot have all of this smooth at 1 constant frame rate. You'd need to use VFR for at least the credit scroll (resolve won't be able to handle it properly) and/or do some resampling/interpolation with something like RIFE to retime the text - but that has potential for generating artifactsLast edited by poisondeathray; 3rd Feb 2025 at 10:18.
Judder effect (Monitor Gigabyte M320q + PotPlayer)
By rRondo in forum Newbie / General discussionsReplies: 13Last Post: 18th Sep 2023, 12:08 -
YouTube adding judder/choppiness to my video
By Kidsnd274 in forum Video Streaming DownloadingReplies: 7Last Post: 23rd Nov 2022, 13:04 -
Handbrake - deblocking has opposite effect??
By starplayer in forum Video ConversionReplies: 7Last Post: 4th Jan 2022, 16:21 -
Tag h.264 as BT.709 in Handbrake GUI
By barmah in forum Video ConversionReplies: 3Last Post: 2nd Jul 2021, 09:54 -
Help Needed with Handbrake Picture Judder
By MoonlightsMuse in forum Video ConversionReplies: 22Last Post: 20th Feb 2021, 03:36
