Hello,
Has anyone tried this? I'd like to be able to encode at the same time 4 minidv via firewire using 4 firewire cards, is that possible?
If so, is there any software that lets you select between several firewire cards?
Thank you for your insight!
not much support for minidv anymore and there was never a multi-cam input mixer for it. there are multi-cam video editing programs that can use dv or get cams with hdmi out and a current standalone video mixer.
Thanks for the reply, I'll try to find out more, I've just unmounted 4 firewire cards.
mpd with multiple periods, multiple keys failing to decrypt
By monk87 in forum Video Streaming DownloadingReplies: 5Last Post: 9th Oct 2024, 16:09 -
Is burning multiple DVDs (of different ISOs) at the same time possible?
By Manulis in forum ComputerReplies: 3Last Post: 28th Oct 2023, 23:26 -
Edit multiple subtitle at once - time shift
By Platos in forum SubtitleReplies: 2Last Post: 2nd May 2023, 15:44 -
How to add the same tags to multiple lines at the same time?
By Malls Baloney in forum SubtitleReplies: 0Last Post: 23rd Sep 2020, 02:57 -
potplayer multiple instances, how to play 2 videos at same time?
By wtfiwinomgs in forum Newbie / General discussionsReplies: 10Last Post: 30th Jun 2020, 19:49
