  1. What is the best brand and model for this type of SATA to USB converter to use in conjunction with a 5.25" DVD Drive and 3.5" HDD? Which brand has the best quality and durability?
    Mar 2021
    Israel
    There is no such a thing as best brand for adapters. Either they work well or they don't.
    Just order a suitable adapter from AliExpress.
    I bought this adapter and I am quite happy with it.
    https://www.aliexpress.com/item/1005004416508484.html?spm=a2g0o.order_list.order_list_...66011802YzIby8
    If you find a cheaper adapter then buy it.
  3. Does any of these models have more stability, heat up less, greater compatibility and durability? Does the chip used in it have an influence?
    Mar 2021
    Israel
    I don't think there is enough data that answers your questions. I suggest to contact few OEM manufacturers (NOT the resellers) and ask them for their input, but I doubt very much if they would bother to answer.
    These adapters are so cheap to manufacture maybe $1-$2 at most, but the end user pays about $20.
