Can anyone tell me what's wrong here?...
I installed devine via pip, cloned SBB+tpd94 services, created .yaml, added .wvd
Services are found:Code:devine cfg --list / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine directories: services: /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/devine/services/ temp: /tmp/devine downloads: /home/pc/Desktop/ wvds: /home/pc/.local/share/devine/WVDs credentials: ALL4: username:password ROKU: username:password CTV: username:password DSNP: username:password downloader: aria2c profiles: default: default dl: sub_format: srt
I haven't added any credentials yet, but I can't search or dl from anywhere:Code:devine dl SERVICE -? / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine Error: "There is no Service added by the Tag 'SERVICE'". Available Services: ALL4, AMZN, AUBC, CBC, CBS, CR, CTV, DROP, DSCP, ITV, MY5, PLUTO, ROKU, RTE, STV, TFC, TUBI, TVNZ, UKTV, VIKI, iP
Code:devine search PLUTO ? / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine Service Config loaded ╭───────────────────── Traceback (most recent call last) ──────────────────────╮ │ /home/pc/Downloads/pyenvs/main/bin/devine:8 in <module> │ │ │ │ 5 from devine.core.__main__ import main │ │ 6 if __name__ == '__main__': │ │ 7 │ sys.argv[0] = re.sub(r'(-script\.pyw|\.exe)?$', '', sys.argv[0]) │ │ ❱ 8 │ sys.exit(main()) │ │ 9 │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:11 │ │ 61 in __call__ │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:10 │ │ 82 in main │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:16 │ │ 97 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:16 │ │ 94 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:14 │ │ 43 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:78 │ │ 8 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/decorators │ │ .py:33 in new_func │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/devine/commands/ │ │ search.py:64 in search │ │ │ │ 61 │ │ │ log.info("Service Config loaded") │ │ 62 │ │ else: │ │ 63 │ │ │ service_config = {} │ │ ❱ 64 │ │ merge_dict(config.services.get(service), service_config) │ │ 65 │ │ │ 66 │ proxy_providers = [] │ │ 67 │ if no_proxy: │ ╰──────────────────────────────────────────────────────────────────────────────╯ AttributeError: 'str' object has no attribute 'get'Does anyone know what's wrong here?Code:devine dl TUBI https://tubitv.com/movies/100032830/new-york-post-presents-luigi-mangione-monster-or-martyr / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine Service Config loaded ╭───────────────────── Traceback (most recent call last) ──────────────────────╮ │ /home/pc/Downloads/pyenvs/main/bin/devine:8 in <module> │ │ │ │ 5 from devine.core.__main__ import main │ │ 6 if __name__ == '__main__': │ │ 7 │ sys.argv[0] = re.sub(r'(-script\.pyw|\.exe)?$', '', sys.argv[0]) │ │ ❱ 8 │ sys.exit(main()) │ │ 9 │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:11 │ │ 61 in __call__ │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:10 │ │ 82 in main │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:16 │ │ 97 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:16 │ │ 94 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:14 │ │ 43 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:78 │ │ 8 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/decorators │ │ .py:33 in new_func │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/devine/commands/ │ │ dl.py:141 in cli │ │ │ │ 138 │ │ │ │ help="Amount of tracks to download concurrently.") │ │ 139 │ @click.pass_context │ │ 140 │ def cli(ctx: click.Context, **kwargs: Any) -> dl: │ │ ❱ 141 │ │ return dl(ctx, **kwargs) │ │ 142 │ │ │ 143 │ DRM_TABLE_LOCK = Lock() │ │ 144 │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/devine/commands/ │ │ dl.py:173 in __init__ │ │ │ │ 170 │ │ │ │ self.log.info("Service Config loaded") │ │ 171 │ │ │ else: │ │ 172 │ │ │ │ self.service_config = {} │ │ ❱ 173 │ │ │ merge_dict(config.services.get(self.service), self.service │ │ 174 │ │ │ │ 175 │ │ with console.status("Loading Widevine CDM...", spinner="dots") │ │ 176 │ │ │ try: │ ╰──────────────────────────────────────────────────────────────────────────────╯ AttributeError: 'str' object has no attribute 'get'
If you still haven't solved your own problem, I notice you do not reference a CDM at all.
I have this line in my yaml.
I have named my cdm as 'device.wvd' and it is in the folder pointed to by WVDs.Code:cdm: default: device
Also formatting - it may be just this site an how it displays stuff - lines ending in a colon (a section heading) are followed by lines indented two spaces. -
Thanks but I already tried tinkering with the cdm setting and it doesn't help:
Code:devine cfg --list / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine directories: services: /home/pc/Downloads/pyenvs/sbbdvine/devine/devine/services/ temp: /tmp/devine downloads: /home/pc/Desktop/ wvds: /home/pc/.local/share/devine/WVDs credentials: ALL4: username:password ROKU: username:password CTV: username:password DSNP: username:password downloader: aria2c profiles: default: default dl: sub_format: srt cdm: default: samsung_sm-a137f_16.1.1_006_8d9ce720_28919_l3Code:devine dl tubi https://tubitv.com/movies/100032830/new-york-post-presents-luigi-mangione-monster-or-martyr / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine Service Config loaded ╭───────────────────── Traceback (most recent call last) ──────────────────────╮ │ /home/pc/Downloads/pyenvs/main/bin/devine:8 in <module> │ │ │ │ 5 from devine.core.__main__ import main │ │ 6 if __name__ == '__main__': │ │ 7 │ sys.argv[0] = re.sub(r'(-script\.pyw|\.exe)?$', '', sys.argv[0]) │ │ ❱ 8 │ sys.exit(main()) │ │ 9 │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:11 │ │ 61 in __call__ │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:10 │ │ 82 in main │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:16 │ │ 97 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:16 │ │ 94 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:14 │ │ 43 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/core.py:78 │ │ 8 in invoke │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/click/decorators │ │ .py:33 in new_func │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/devine/commands/ │ │ dl.py:141 in cli │ │ │ │ 138 │ │ │ │ help="Amount of tracks to download concurrently.") │ │ 139 │ @click.pass_context │ │ 140 │ def cli(ctx: click.Context, **kwargs: Any) -> dl: │ │ ❱ 141 │ │ return dl(ctx, **kwargs) │ │ 142 │ │ │ 143 │ DRM_TABLE_LOCK = Lock() │ │ 144 │ │ │ │ /home/pc/Downloads/pyenvs/main/lib/python3.11/site-packages/devine/commands/ │ │ dl.py:173 in __init__ │ │ │ │ 170 │ │ │ │ self.log.info("Service Config loaded") │ │ 171 │ │ │ else: │ │ 172 │ │ │ │ self.service_config = {} │ │ ❱ 173 │ │ │ merge_dict(config.services.get(self.service), self.service │ │ 174 │ │ │ │ 175 │ │ with console.status("Loading Widevine CDM...", spinner="dots") │ │ 176 │ │ │ try: │ ╰──────────────────────────────────────────────────────────────────────────────╯ AttributeError: 'str' object has no attribute 'get' -
Your first post has this
Which suggests you've got a folder within 'services' called 'SERVICE'. That would explain why services.get() is failing.Code:Error: "There is no Service added by the Tag 'SERVICE'".
So go to your services folder and remove anything which does not have a legit service in it. -
Nearly 5 months later and I finally fixed this - there was a formatting error in my .yaml
Running DEVINE in RAM only
By pssh in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Dec 2024, 12:38 -
Devine on Android
By PSXman_uk in forum Video Streaming DownloadingReplies: 5Last Post: 2nd Nov 2024, 16:07 -
Help With Writing First Devine Service
By stevepen1974 in forum Video Streaming DownloadingReplies: 4Last Post: 16th Aug 2024, 14:27 -
help with install Devine
By macos in forum Video Streaming DownloadingReplies: 2Last Post: 14th Aug 2024, 04:58 -
CW Network Devine service script?
By Danker1990 in forum Video Streaming DownloadingReplies: 0Last Post: 23rd Jul 2024, 08:49
Good luck.
