My Lite-On iHAS122-14 FU (actually firmware EL06) DVD drive no longer recognizes M-Disc DVD media. A few years ago I burned some M-Disc DVDs to this drive. My other ASUS 24x Drw-24f1mt drive can read and burn them normally.
Is there any new custom firmware available for the Lite-On iHAS122 F to restore M-Disc DVD support?
Perhaps you don't need a new firmware to sort this out. Even if you find a new firmware, there is no guarantee that this will solve the issue.
Do you know when did you notice that the Lite-On DVD drive wouldn't recognize the M-Discs?
Was it a something recent after installing some software?
What I would do is enter BIOS and reset everything to default values. Then check.
In addition you can uninstall the Lite-On drive from the Device Manager, reboot and check.
Are the two DVD drives on the same PC or different and what is your operating system? -
1) Using cdburnerxp I burned a DVD mdisc on a Lite-On iHAS122-14 FU drive (currently firmware EL06) that previously burned and read DVD mdiscs. After burning, the burning test (if the burning was completed successfully) failed. Now, on that same drive, if I put the disc in, nothing appears. I put the disc in an old ASUS drive of my friend and it loaded without any files. I put the disc in my ASUS 24x Drw-24f1mt drive and the files appeared, but only some of them could be extracted because during the extraction it crashes. Is this behavior normal for a poorly burned DVD mdisc? It is very strange that cdburnerxp shows recording completed, fails the test after recording and the files do not appear on some drives.
2) All my other recordings with other mdisc DVDs and the test after burning were completed well but using the ASUS 24x Drw-24f1mt drive.
3) The disc was recorded as CDFS. Is this format compatible for reading and copying files universal to SATA drives? -
only some ihas122 drives have mdisc compatibility. you seem to have flashed the drive to a different firmware than it came with. that most likely removed it's mdisc ability. there's no going back gamemaniaco.
No i not update firmware
2) The disc was recorded as CDFS. Is this format compatible for reading and copying files universal to SATA drives?
3)When the recording is completed or there is an error during the recording of the mdisc DVD and after that the liteon drive does not recognize the disc, another asus drive recognizes the disc as empty and another more modern asus drive shows the files that were partially recorded, what does this mean?
Insignia NS-BRDVD2 / NS-BRDVD3 / NS-BRDVD4 -region hack firmware question
By Jack Torrance in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2024, 18:47 -
Liteon iHAS324 DVD Drives need to disable low noise feature = slow rip spee
By s8n in forum DVD & Blu-ray WritersReplies: 1Last Post: 31st Jul 2024, 20:24 -
Copy BitLocker-Encrypted NVME Boot Drive to Larger NVME Replacement Drive
By usually_quiet in forum ComputerReplies: 9Last Post: 10th Dec 2021, 13:05 -
firmware for samsung model drive
By datastore in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Jan 2021, 07:24 -
Question buy dvd drive
By datastore in forum DVD & Blu-ray WritersReplies: 1Last Post: 26th Dec 2020, 04:51
