It seems like there is a bug in .11 preventing space bar from being used to start and stop playback.
Anyone else?
I changed play/pause in settings as well from Control+P to space only, and it was still broken for me.
I tried uninstalling, reinstalling. Didn't work. Uninstalled, restarted, reinstalled, restarted, still broken.
Uninstalled, then reinstalled 4.0.10 and can confirm spacebar works on that version. For now, 11 is broken it seems like.
Please confirm this for me.
I can confirm in SE 4.0.11 the space-bar indeed doesn't work to play/pause video.
Thanks!
Found this on Doom9: https://github.com/SubtitleEdit/subtitleedit/issues/9289 -
Thanks Dave. It activates on audio then. And also in the 4.0.11? Problem solved?
How to Limit Subtitle Lines to 3 Words in Subtitle Edit?
By rowise in forum SubtitleReplies: 2Last Post: 2nd Jan 2025, 10:24 -
Subtitle Edit - delete video and subtitle file after processing?
By svcds in forum SubtitleReplies: 0Last Post: 4th Jan 2024, 05:45 -
Subtitle edit - How to put 'A with a dash on top' in subtitle edit?
By SSEN in forum SubtitleReplies: 5Last Post: 21st Sep 2023, 20:57 -
Subtitle Edit : Capitalize Subtitle to Normal Subtitle incomplete
By kalemvar1 in forum SubtitleReplies: 6Last Post: 5th Aug 2023, 12:28 -
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 06:44
