I have kept all of my raw lossless vhs capture avi's, around 2.0TB, who knows if I'll ever use them again, but in the future world of AI who knows.
7zip has a 98% compression ratio, which really isn't worth the time. I haven't seemed to find any other options but thought I'd ask as I havent found any recent threads on the subject.
Are they uncompressed AVI or losslessly compressed, Because lossless compression can save you up to 40%, albeit it's a tedious work. Though a 2TB is around $60, so I would just put them in a hard drive and forget about them.
FFV1 should deliver higher lossless compression than 7z - it is tailored for video and 7z i general purpose.
I also agree that lossy (but imperceptible) compression with modern video codec can be acceptable (depends on your criteria).
Give a chance to FFV1 - if not try lossless H.264/265 but also test minimal lossy way (like qp=4). -
As dellsam34 says, keep your raw lossless capture as they are. They are your masters for present and future enhacement, if any.
More advanced techniques can be used for extremely important material (error detection and correction, storage of 3x copies in 3 different places, etc) but that’s too much for you I suppose. -
Thank you for the replies. They're the AVI's created during capture with lagarith. Yes, I just didn't know if there was anything that reduced them even further like zip or 7z. Just wanted to make sure that there wasn't something obvious before I spend the money on hard drives for only something that I "might" use in the future (HDD prices havent come down in price for quite some time now).
Lagarith (and all the other lossless video codecs) use algorithms very similar to the archivers like 7zip, WinRar, etc. So those programs won't get you much more compression unless there's some other uncompressed data within the video file (uncompressed audio, subtitles, padding, etc.).
Some discussion on using x264/x265 with crf 0 (lossless) for compressing these raw captures. Considering doing some testing on my own, as I have about 60TB of UTVideo and Huffyuv captures for long term archival.
Seems in testing this person was able to compress and uncompress and get an exact result back, while also cutting the size down drastically.
https://www.reddit.com/r/DataHoarder/comments/1g0g1pf/should_i_winrar_archive_raw_vhs_records_or/
Newbie long term storage question
By Thomas Elfe in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2024, 21:21 -
Which format & bitrate is better to download for long-term collecting?
By gs684 in forum Video Streaming DownloadingReplies: 2Last Post: 21st Jun 2023, 01:16 -
Recommendations for long-term future compatibility
By copperheadclgp in forum Video ConversionReplies: 2Last Post: 19th Sep 2022, 07:22 -
SSD no good for long term storage?
By mazinz in forum ComputerReplies: 10Last Post: 10th Jul 2022, 01:09 -
Should my long term storage master be de-interlaced?
By 22west in forum Capturing and VCRReplies: 3Last Post: 23rd Jan 2022, 20:11
