What free program offers change in audio background noise to highten volume contrast (cancel loud noise out & maximize output volume for background noise?
Any chance of uploading a noisy audio example to demonstrate what you need to fix?
It depends on what you are trying to achieve.
Watching movies, playing music on a computer, VLC can achieve that on the fly through the Adjustment and Effects settings. If you want a permanent adjustment embedded into the audio of, say, a video, you will have to demux, adjust and remux (maybe Audacity for adjustment)
What is the most comprehensive free Audio editing program?
By Halobolt07 in forum AudioReplies: 2Last Post: 10th Feb 2025, 08:14 -
Clearing out background noise after using a stem splitter
By imkira3 in forum AudioReplies: 8Last Post: 17th Jun 2023, 03:24 -
Are the levels of background noise too high for this VHS capture?
By Desve in forum AudioReplies: 44Last Post: 26th Jun 2022, 14:39 -
free audio software that allows me to view/change ch distribution for 5.1?
By Oripot in forum AudioReplies: 1Last Post: 25th Jul 2021, 20:02 -
Capture program for 8mm only offers mpeg2. Is there better quality?
By hpcampr in forum Capturing and VCRReplies: 80Last Post: 28th Apr 2020, 15:13
