  1. I have a movie where the subtitles are below the picture, in the black letterbox bars. I want to move them up, into the picture area. Is there an easy way to do this? Subtitle Edit will let me reposition each line individually, but I don't really fancy doing that for thousands of lines...
  2. Member Ennio's Avatar
    May 2005
    Netherlands
    In SE's SUP editor settings, set your desired bottom value. Then select all (Ctrl A) and go Tools --> Alignment and choose Bottom/center.
  3. Works perfectly!
  4. Actually scratch that, if I bulk select it keeps marking all the selected lines as "forced," which a) ties the program up for ages while it does that and b) I don't want to do.
  5. Member Ennio's Avatar
    May 2005
    Netherlands
    Not over here. Selecting all using Ctrl+A doesn't set any line as forced. I'm on Subtitle Edit version 4.0.10
  6. Ctrl+A doesn't, no. But I had a subtitle where some were top-aligned, and shift-clicking to select multiple lines caused everything to get marked as forced.
  7. Member Ennio's Avatar
    May 2005
    Netherlands
    ...shift-clicking to select multiple lines caused everything to get marked as forced.
    This is annoying behaviour indeed. Selecting lines should be a separate step from marking them as forced.
    As a workaround directly after selecting, you can rightclick on the still selected lines and toggle forced. This will take away the forced marks.
