Results 1 to 22 of 22
    Jan 2025
    Columbia River Gorge
    I've been using VirtualDub2_44282 and just downloaded the latest version 2.1.3.667. I extracted the files and when I try to run VirtualDub64 the screen dims slightly like something is starting to run and then nothing. There's no VirtualDub2 window and the process doesn't appear in the TaskManager.
    How does one get VirtualDub2 to run? Thanks.
    Mar 2008
    Doubleclick or create a shortcut to the executable
    Jan 2025
    That's what I'm doing, double-clicking on the executable but as explained it does nothing. The 44282 version works fine though.
    Mar 2008
    It works ok for me in Windows 10. Where did you download it from?
    Check your A/V in case any action was logged
    Jan 2025
    I downloaded it from this site from the link here:
    https://www.videohelp.com/software/VirtualDub2
    I use Windows "Virus & threat protection" in Windows 11 that I keep updated. There are no malware threats listed. There we no firewall notices.
    Strange, I can start the 44282 version of VirtualDub2 but not the v2.1.3.667 version.
    May 2005
    PAL User
    Same here. 2.1.3.667 will not open in Win 11 23H2.
    Apr 2007
    Australia
    Empty your plugins64\ folder and try running virtualdub64 without them.
    If vdub starts, add back a couple of plugins at a time.
    May 2005
    PAL User
    "Your" plugins folder? Each version comes with it's own plugins folder. Are you saying the original plugins folder is used by the new version?
    BTW, HAD!
    Mar 2008
    I opened an "issue" at Github
  10. 2.1.3.667 from https://www.videohelp.com/download/VirtualDub2_v2.1.3.667.7z
    works fine here (Windows 11 24h2_26100_3025).
    Maybe you have leftovers from previous versions in your user profile.
    Search for virtualdub folders recursively in c:\users and delete every folder that is found.
    Jan 2025
    BTW, HAD!
    The 44282 and 2.1.3.667 versions unzipped to their own folders.
    In the 2.1.3.667 version I tried moving all the plugins out of the plugins64 folder and same result. Double-clicking on VirtualDub64.exe dims the screen for a brief moment and then nothing.
    Jan 2025
    I looked in %appdata% and didn't see anything related to VirtualDub.
    When running the 44282 version I don't see there are any settings to specify a startup folder, temp folder, or anything like that which could affect the 2.1.3.667 version.
  13. Check your system.
    Download Dism-Gui here:
    https://files.videohelp.com/u/292773/Dism-gui.zip
    Execute it and click SFC scan.
    Wait until is finished.
    If errors are found and fixed, restart the computer and repeat the operation.
    If no erros are found, click Restore, then on restore source click online.
    This will repair your component store, if faulty.
    If repair is successfull, restart the computer and retry to start Virtualdub2.
  14. Video Restorer lordsmurf's Avatar
    I didn't think VirtualDub2 could get more buggy.
    I was wrong.
    I'm still waiting for the resize filter to be fixed, and I reported it years ago.
    Mar 2008
    If you want to reset vdub2 from the registry, close all instances of vdub2,
    open Regedit, navigate to this key in the left pane and rename:
    HKEY_CURRENT_USER\SOFTWARE\VirtualDub.org
    rename to
    HKEY_CURRENT_USER\SOFTWARE\VirtualDub.orgold
    Jan 2025
    rename to
    I don't have a VirtualDub.org key in the registry. Maybe I'm using only portable versions.
    Mar 2008
    download a fresh copy
    Right click the 7z file and select properties/unlock.
    Extract to a new folder.
    Try it again/check the registry key
  18. Member
    May 2005
    PAL User
    I've got 2.1.3.667 working here now after a computer restart. No unblocking or registry clearing required.
    Mar 2008
    Does the registry key get created?
    May 2005
    PAL User
    There's one there; don't know which version put it there though, I have run a few VDubs.
    Mar 2008
    44282 and v2.1.3.667 share that key, not sure about other versions
  22. Member
    Jan 2025
    Never mind
