I'm converting some E-AC3 files to opus. If I use ffmpeg to do it one step, I run into problems. So I wrote a simple script to use eac3to to decode to wav, then ffmpeg to convert the resulting wav to opus. It works but unless I specify -removeDialnorm, I get the message "keeping dialnorm" from eac3to.
I've updated my script to specify -removeDialnorm, but I thought that was the default anyway. Am I correct in wanting to remove dialnorm when doing this conversion?
Results 1 to 1 of 1
Any way to use eac3to.exe with Wine?
By beerninja in forum LinuxReplies: 5Last Post: 25th Oct 2024, 14:29 -
DVD Styler - Quick Question
By Libertine90 in forum Authoring (DVD)Replies: 1Last Post: 29th Sep 2024, 13:27 -
eac3to decoder pack
By Laflame in forum Blu-ray RippingReplies: 0Last Post: 8th Apr 2024, 18:10 -
Quick Dot Crawl /Antialiasing Avisynth Question
By Vaengence in forum Video ConversionReplies: 6Last Post: 15th Dec 2021, 21:26 -
eac3to volume difference
By killerteengohan in forum RestorationReplies: 0Last Post: 2nd Apr 2021, 05:06
