Got a Onkyo receiver and want to connect with Monster wireless speaker. Onkyo is Bluetooth too. The Monster has a 3.5mm connector aux on the front. Is any way to connect it?
AUX is probably input so you need to find line output on Onkyo and connect it with cable - not sure if Onkyo being itself amplifier support output over BT. If you need wireless connection then perhaps you should find module (Aliexpress?) with analog audio input and BT output.
Check user manual for your Onkyo model - they should provide connectivity options. -
[QUOTE=pandy;2764949]AUX is probably input so you need to find line output on Onkyo and connect it with cable - not sure if Onkyo being itself amplifier support output over BT. If you need wireless connection then perhaps you should find module (Aliexpress?) with analog audio input and BT output.
Check user manual for your Onkyo model - they should provide connectivity options.[
There is no book at the box. -
I think the Onkyo model you mentioned should be TX-NR5100
I couldn't find any mention of TC-NR5100
Assuming your exact model is TX-NR5100, this model has bluetooth feature.
Please see the attached user manual. Read relevant section regarding bluetooth connectivity starting page 54-58
Hope this helps -
New Satellite Receiver: New Way To Capture
By Tom Saurus in forum Capturing and VCRReplies: 26Last Post: 19th Jul 2024, 14:32 -
Need to Connect Media Room Receiver to Family Room Receiver
By hannahsdad in forum Media Center PC / MediaCentersReplies: 5Last Post: 18th Sep 2023, 16:21 -
Connections to a receiver
By keyboard in forum AudioReplies: 1Last Post: 21st Apr 2021, 16:08 -
Best Successors to Monster Power Centers ?
By Seeker47 in forum Newbie / General discussionsReplies: 5Last Post: 30th Nov 2020, 11:24 -
Onkyo bd_sp353 to make region free
By Emi_ in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Feb 2020, 22:01
