Ok I have newest version of v dub.. I finished encoding lotr today.. then when I started next audio conversion I get a error that says the requested audio compression is not compatible with imput format check sampling rate and channel count. I noticed in file information that it shows compression as "unknown"tag 0055
any movie I load shows this way.. I uninstalled and reinstalled the program.. to no avail.. I saw a post where the guy had the same problem but after searching the forum I found no answer.. It was working fine.. a little help please???
Your avi file probably has multichannel AC3 audio. Use Besweet to extract and convert to stereo. Search to forum and the guides for details.
the problem is that all my movie files are reading this way now.. even avi masters I had already encoded and burnt.. but I found the answer about 3 am this morning... I noticed some of my music video mpegs were showing the codec in the compression slot.. so I uninstalled my codec nimo pack and reinstalled it and it fixed it..... apparently one of the codecs became corrupted.. hope this helps some others who had the same problem
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Need help with Virtual Dub setting
By lost123 in forum Capturing and VCRReplies: 12Last Post: 8th Jul 2010, 21:31 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 19:00 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36
