I want to use vsmlrt to remove rainbows and slight colour bleed in my source using https://openmodeldb.info/models/1x-BleedOut-Compact
But I'm not sure how to use this plugin. There's no parameter doc anywhere and I'm not sure where to put this .pth file. I have downloaded vsmlrt and dragged and dropped into my plugins folder but not sure what do from there
This is my script so far
Code:import vapoursynth as vs import fvsfunc as fvf import kagefunc as kgf import vsTAAmbk as taa import functools import mvsfunc as mvf import lvsfunc as lvf import havsfunc as haf import vsmlrt from vsutil import * from nnedi3_rpow2 import * core = vs.core def postprocess(n, f, clip, deinterlaced): if f.props['_Combed'] > 0: return deinterlaced else: return clip def decimate(src): src = core.vivtc.VFM(src, 1) return core.vivtc.VDecimate(src) def detelecine(src): matched = core.vivtc.VFM(src, 1) src = core.nnedi3.nnedi3(src, field=0) return core.std.FrameEval(matched, functools.partial(postprocess, clip=matched, deinterlaced=src), prop_src=matched) src = core.dgdecodenv.DGSource(r"E:\VapWork\Hare\VTS_02_1.dgi") src = core.tcomb.TComb(src, mode=2) src = core.bifrost.Bifrost(src, interlaced=True) src = haf.Stab(src, range=5, mirror=0, dxmax=8, dymax=8) src = decimate(src) src = core.reduceflicker.ReduceFlicker(src, strength=3, aggressive=1) src = fvf.Depth(src, 16) crop = core.std.CropRel(src, 10, 8, 2) scaled = core.resize.Spline36(crop, 720, 540) aamask = kgf.retinex_edgemask(scaled).std.Binarize(12000).std.Inflate() aa = taa.TAAmbk(scaled, aatype='Nnedi3', mclip=aamask) dehalo = haf.HQDeringmod(aa, darkthr=0, sharp=0, mthr=54) dpir = lvf.deblock.vsdpir(dehalo, strength=40, mode='deblock', cuda=True, matrix="6") denoise = haf.SMDegrain(dpir, tr=3, thSAD=220, RefineMotion=True) line_mask = kgf.retinex_edgemask(denoise, sigma=1) mask_outer = iterate(line_mask, core.std.Maximum, 3) dpir_merge = core.std.MaskedMerge(dehalo, denoise, mask_outer)
How do I use this .pth file and call it to vapoursynth? Any help is appreciated thank you!
Sure, there is: Since I use vsort I followed https://github.com/AmusementClub/vs-mlrt/tree/master/vsort (which is linked on the main page)There's no parameter doc anywhere and ...
Docs for the other methods are also linked on the main page.
You can't use .pth files, you would need to use VSGAN for .pth files.I'm not sure where to put this .pth file.
You only can use .onnx files with vsmlrt, but you can convert .pth to .onnx using https://github.com/chaiNNer-org/chaiNNer.
Here's an example how I use vs-mlrt with the an .onnx model.
Here's also an example how I use it using VSGAN:Code:# Imports import vapoursynth as vs # getting Vapoursynth core import site import sys import os core = vs.core # Import scripts folder scriptPath = 'F:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) os.environ["CUDA_MODULE_LOADING"] = "LAZY" # loading plugins core.std.LoadPlugin(path="F:/Hybrid/64bit/vs-mlrt/vstrt.dll") core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/SourceFilter/LSmashSource/LSMASHSource.dll") # Import scripts from importlib.machinery import SourceFileLoader vsmlrt = SourceFileLoader('vsmlrt', 'F:/Hybrid/64bit/vs-mlrt/vsmlrt.py').load_module() import validate # Source: 'G:\TestClips&Co\files\test.avi' # Current color space: YUV420P8, bit depth: 8, resolution: 640x352, frame rate: 25fps, scanorder: progressive, yuv luminance scale: limited, matrix: 470bg, format: MPEG-4 Visual # Loading G:\TestClips&Co\files\test.avi using LWLibavSource clip = core.lsmas.LWLibavSource(source="G:/TestClips&Co/files/test.avi", format="YUV420P8", stream_index=0, cache=0, prefer_hw=0) frame = clip.get_frame(0) # setting color matrix to 470bg. clip = core.std.SetFrameProps(clip, _Matrix=vs.MATRIX_BT470_BG) # setting color transfer (vs.TRANSFER_BT601), if it is not set. if validate.transferIsInvalid(clip): clip = core.std.SetFrameProps(clip=clip, _Transfer=vs.TRANSFER_BT601) # setting color primaries info (to vs.PRIMARIES_BT470_BG), if it is not set. if validate.primariesIsInvalid(clip): clip = core.std.SetFrameProps(clip=clip, _Primaries=vs.PRIMARIES_BT470_BG) # setting color range to TV (limited) range. clip = core.std.SetFrameProps(clip=clip, _ColorRange=vs.RANGE_LIMITED) # making sure frame rate is set to 25fps clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # making sure the detected scan type is set (detected: progressive) clip = core.std.SetFrameProps(clip=clip, _FieldBased=vs.FIELD_PROGRESSIVE) # progressive # changing range from limited to full range for vsVSMLRT clip = core.resize.Bicubic(clip, range_in_s="limited", range_s="full") # setting color range to PC (full) range. clip = core.std.SetFrameProps(clip=clip, _ColorRange=vs.RANGE_FULL) # adjusting color space from YUV420P8 to RGBH for vsVSMLRT clip = core.resize.Bicubic(clip=clip, format=vs.RGBH, matrix_in_s="470bg", range_s="full") # resizing using VSMLRT, target: 640x352 from vsmlrt import Backend clip = vsmlrt.inference([clip],network_path="F:/Hybrid/64bit/onnx_models/1x_BleedOut_Compact_300k_net_g.onnx", backend=Backend.TRT(fp16=True,device_id=0,num_streams=1,verbose=True,use_cuda_graph=False,workspace=1073741824,builder_optimization_level=3,engine_folder="J:/TRT")) # 640x352 # changing range from full to limited range for vsVSMLRT clip = core.resize.Bicubic(clip, range_in_s="full", range_s="limited") # adjusting output color from: RGBH to YUV420P10 for NVEncModel clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, matrix_s="470bg", range_s="limited", dither_type="error_diffusion") # set output frame rate to 25fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # output clip.set_output()
Hope that helps a bit. Will not exactly work like in my setup since I use a portable Vapoursynth&Python.Code:# Imports import vapoursynth as vs # getting Vapoursynth core import sys import os core = vs.core # Import scripts folder scriptPath = 'F:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # loading plugins core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="F:/Hybrid/64bit/vsfilters/SourceFilter/LSmashSource/LSMASHSource.dll") # Import scripts import validate # Source: 'G:\TestClips&Co\files\test.avi' # Current color space: YUV420P8, bit depth: 8, resolution: 640x352, frame rate: 25fps, scanorder: progressive, yuv luminance scale: limited, matrix: 470bg, format: MPEG-4 Visual # Loading G:\TestClips&Co\files\test.avi using LWLibavSource clip = core.lsmas.LWLibavSource(source="G:/TestClips&Co/files/test.avi", format="YUV420P8", stream_index=0, cache=0, prefer_hw=0) frame = clip.get_frame(0) # setting color matrix to 470bg. clip = core.std.SetFrameProps(clip, _Matrix=vs.MATRIX_BT470_BG) # setting color transfer (vs.TRANSFER_BT601), if it is not set. if validate.transferIsInvalid(clip): clip = core.std.SetFrameProps(clip=clip, _Transfer=vs.TRANSFER_BT601) # setting color primaries info (to vs.PRIMARIES_BT470_BG), if it is not set. if validate.primariesIsInvalid(clip): clip = core.std.SetFrameProps(clip=clip, _Primaries=vs.PRIMARIES_BT470_BG) # setting color range to TV (limited) range. clip = core.std.SetFrameProps(clip=clip, _ColorRange=vs.RANGE_LIMITED) # making sure frame rate is set to 25fps clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # making sure the detected scan type is set (detected: progressive) clip = core.std.SetFrameProps(clip=clip, _FieldBased=vs.FIELD_PROGRESSIVE) # progressive # changing range from limited to full range for VsVSGANFilter clip = core.resize.Bicubic(clip, range_in_s="limited", range_s="full") # setting color range to PC (full) range. clip = core.std.SetFrameProps(clip=clip, _ColorRange=vs.RANGE_FULL) # adjusting color space from YUV420P8 to RGBH for VsVSGANFilter clip = core.resize.Bicubic(clip=clip, format=vs.RGBH, matrix_in_s="470bg", range_s="full") # filtering using VSGANFilter from vsgan import ESRGAN vsgan = ESRGAN(clip=clip,device="cuda") model = "F:/Hybrid/64bit/vsgan_models/1x_BleedOut_Compact_300k_net_g.pth" vsgan.load(model) vsgan.apply() # 640x352 clip = vsgan.clip # changing range from full to limited range for VsVSGANFilter clip = core.resize.Bicubic(clip, range_in_s="full", range_s="limited") # no resizing since resolution is already archived # adjusting output color from: RGBH to YUV420P10 for NVEncModel clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, matrix_s="470bg", range_s="limited", dither_type="error_diffusion") # set output frame rate to 25fps (progressive) clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # output clip.set_output()
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Thanks for responding, how do I convert it? Also it seems I need an engine file?
EDIT: I tried VSGAN, but it seems RGB is not even compatible with even half my filtersLast edited by hihflappy; 23rd Jan 2025 at 18:37.
vs-mlrt and vsgan both use RGH and RGBS. If your filters do not support these, convert to a color format that is supported before applying them,...I tried VSGAN, but it seems RGB is not even compatible with even half my filters
https://github.com/upscayl/upscayl/wiki/Model-Conversion-Guide/306dae7c1251659b979a30a...a2c616ddf8a3e8how do I convert it?
Engine files get automatically generated (by vs-mlrt) when using TRT as backend.Also it seems I need an engine file?
