Hi guys,, I am going to replace//upgrade my D620 CPU currently an (Intel CPU T2400, 1.83 GHz x 2), to a T7600 CPU.
Seen one on Ebay, asked Chinese seller if it would work in a DELL D620 laptop he has requested two questions be answered.
(1)What processor was your original configuration?
Does this mean the hardware spec from system info as listed above, ,plus basic system info?
(2) What is your motherboard's northbridge chip?
I do not know what this means, or where to find it? Any help here welcomed.
The original D620 O/S is a win 7 home, 32 bit, but this O/S is no longer booting (recently) ,after the Dell logo screen a series of beeps, but no boot. I am currently using Linux Mint 16 to access the System info details. If you have any experience with this model, upgrading the CPU, any help welcomed. Cheers.
All the best
visionman
Health IS the first Wealth------So do not strain your eyes!
you should be able to find this info. Use HWinfo, see the motherboard section/chipset
https://www.hwinfo.com/download/ -
I have one of those still too, but not in use.
But what problem exactly you are trying to fix now?
The non booting OS?
Best upgrade would be to put in a SSD, that will have more impact then using a higher CPU and much easier to do.
Also you can find with a bit google:
Dell Latitude D620 CPU upgradeLast edited by The_Doman; 22nd Jan 2025 at 07:36.
Thanks both, Davexnet, for a nice bit of kit that could be very useful at the present, and future. Have decided not to go with the T7600 CPU, or the T7400, or indeed the ( T7200 ) after a lot of research. A bit of a nightmare researching these CPUs. The original T2400 in the D620 is a 32 bit architecture CPU and so is all the rest of the Hardware connected to it (Northbridge Chipset) It may well be possible to upgrade this model but I am not going to experiment with it. The-Domain thanks for assisting me in thinking in a different direction that produced a lot of useful ideas and solid data. I have fixed the issue, I am going to buy another laptop, 64bit with a bit of tech future proofing, and install Linux Mint 19 onto the D620. I have a new 250GB SSD, It may help booting a new install of win7, thanks for the advice, sound reasoning but the 32 bit system limitations with windows O/S, is too time consuming to experiment with on this retro machine that works really well with Linux. Was worth having a look at the options. Thank you both for your advice and links, appreciated.
visionmanHealth IS the first Wealth------So do not strain your eyes! -
and thats davexnet and The_Doman, oops!
Dell Precision T3500, which Gaming PC case does it FIT?
By OldSchool297 in forum ComputerReplies: 3Last Post: 11th Nov 2022, 09:55 -
Dell T3500 play HD video.
By OldSchool297 in forum ComputerReplies: 0Last Post: 19th Oct 2022, 04:51 -
Dell, Lenovo and HP kill laptops with hard disk drives.
By El Heggunte in forum ComputerReplies: 8Last Post: 18th Jun 2022, 04:31 -
Selling an old Win XP desktop PC and Dell monitor
By techmot in forum ComputerReplies: 17Last Post: 8th May 2022, 22:01 -
Liongate Movie not recognized on Matshita player mounted on Dell on Dell PC
By bigbill10 in forum Authoring (DVD)Replies: 9Last Post: 4th Jul 2020, 17:11
