Hi everyone, i posted this up in one of my other Threads, but i thought i might post this up here as a separate Topic in the hope i can find a solution.
Up until yesterday when i open my VRD Pro to add Titles to my 4k/60p HEVC and AVC Video Files (after Cutting and Smart Rendering them with LosslessCut) they have been working perfectly fine, and also work if i import those files directly into VRD without cutting, the Titles would also work fine as well.
I have a 17" Metabox Laptop with 6 core cpu and 16gb of ram, HD630 Intel graphics + GTX1050 as well.
For some strange reason as from yesterday i can't do it any more because i get this LargeBufferMalloc:no more memory
I think i was getting some of these errors several years ago and the late Dan Rosen explained it to me, but the so called bug that he found in VRD that was causing this was fixed.
I have tried this more than 50 times by now and it seems to happen as soon as the Ram Usage gets to about 50% and the SWAP Usage hits 61% but i have seen it happen a few times when the SWAP Usage has been down at 45%
[Attachment 85004 - Click to enlarge]
I reboot the laptop and the Memory returns to around 20% and the Swap Usage shows up as around 15% but when i try to add a Title again using VRD the Swap Usage goes back up to over 50%, and crashes at 61% or higher while processing.
This process does not Recode my Files, it only renders the Title component so there shouldn't be too much stress on the system.
Does anyone know why this could be happening again, it just seems strange because in the past 4 to 6 weeks i have been testing expensively with other Software to work along side my VRD Pro and my Titles always worked in most cases.
Cheers
Results 1 to 1 of 1
how do you join multiple titles?
By Dr_Sanguinary in forum Newbie / General discussionsReplies: 13Last Post: 11th Nov 2024, 13:29 -
Out of bounds memory error in VirtualDub2
By SVAPrjm in forum Video ConversionReplies: 5Last Post: 11th Jul 2024, 07:47 -
a mysterious error adding time in Subtitle Edit
By loninappleton in forum SubtitleReplies: 1Last Post: 28th Mar 2023, 23:00 -
Pinnacle Studio 11 "Out of Memory" error
By wfo in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jan 2021, 15:28 -
DVDShrink Out of Memory Error
By CamelByte in forum DVD RippingReplies: 0Last Post: 13th Apr 2020, 11:29
