How can I modify the subtitles vertical position with SubtitleEdit?
I normally go to "Video" and select "Generate video with burned-in subtitles", and then the subtitles automatically appear at the very bottom of the screen, but I need to move them 2 or 3 lines up.
Any suggestion will be greatly appreciated.
Marcial
I think you need to adjust the positioning of the subtitles first and then use "Generate video with burned-in subtitles".
This video should help you.
https://www.youtube.com/watch?v=4Wtgh3i50v8
How to overlap .ass subtitles in SubtitleEdit?
By nttell in forum SubtitleReplies: 6Last Post: 5th Jul 2023, 15:36 -
How to change subtitles vertical position with tsMuxer 2.6.12 ?
By Marcial in forum User guidesReplies: 2Last Post: 26th May 2023, 10:31 -
SubtitleEdit – Word split
By Moralez in forum SubtitleReplies: 3Last Post: 26th Jun 2022, 08:04 -
Webvtt Subtitles positioning
By SubtitleNoob in forum SubtitleReplies: 1Last Post: 27th Jul 2020, 13:14 -
How to make vertical Subtitles?
By jsaechao1 in forum SubtitleReplies: 2Last Post: 12th Jun 2020, 13:07
