I Have just used DVDStyler and found it good to use however when I try to burn a DVD it keeps asking for a blank disc despite trying known good media . I can creat ISO files OK. but it seems that it does not reconise the DVD device. Any ideas ? running win 11
So what is this 'known good media' ?
Also have you burnt any disks before ? I do not know how Win11 reports hardware but are you sure you actually have a dvd-burner and not a simple dvd-player. -
The media it rejected I later tried in an old XP laptop and it burnt a video OK. The drive is shown as D: DVD/CD R/W and I can burn audio CD's no problem.
Install ImgBurn if you do not have it.
Select Tools/Drive/Capabilities .
That should give you a lot more information about the drives write capabilities.
Also the actual drive model information not just "D: DVD/CD R/W".
Then try a burn with ImgBurn.
You do not need to create an .ISO.
Just use Mode/Build & Browse for a folder.
Use the VIDEO_TS folder of the DVD you want to burn(Write).
Please help. ALL burns fail; regardless of app, drive, media or format.
By smackyourfupa in forum DVD & Blu-ray WritersReplies: 13Last Post: 20th Jan 2025, 03:26 -
yt-dlp error/fail 'too many requests'
By abrogard in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2024, 23:09 -
MP4 files with QT Audio fail in Avidemux
By abeelandig in forum EditingReplies: 11Last Post: 9th Nov 2023, 06:50 -
Fail to get keys from this site.
By lllllll in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Jun 2022, 12:28 -
streamlink configuration Fail
By hasomaso in forum Video Streaming DownloadingReplies: 2Last Post: 27th Jun 2021, 03:26
