I'm trying to capture some old video tapes from a Sony handycam CCD-TR105E to computer using av to USB2.0 device. After cleaning the tape heads I'm getting a good picture on the camcorder viewfinder but a very poor, if any, picture from the av output. The picture is the same on a TV as it is in my capture software, so I don't think its the AV to USB2.0 device at fault. I've searched on Youtube, but can't find any suggestions other than cleaning the tape heads. One thing I did see though is that the capacitors may leak on the electronics as these are 30 years old. Has anyone else got any further suggestions for rescuing these old tapes please? Thoughts?![]()
Yes it's possible the surface mount caps in your Sony are failing or at least some of them are. In those models these caps started failing many years ago as they did in many electronic appliances back then. Possibly some or all of these many caps were replaced at some stage but are now ready to be replaced again. A good tech can often replace them if the rest of the camcorder is sound. The fact that you have a good image in your (black and white?) viewfinder, suggests maybe only the video output stage has faulty caps. The audio too can fail due to failed or failing caps. Unfortunately if left too long the leaked electrolyte from the caps can damage the circuit board which can complicate things.
Thanks for the reply. Yes, it's a black and white display in the viewfinder. The sound seems ok.
Does this Sony Handycam exist?
By philipus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 16th Jul 2024, 22:16 -
help with capturing dv footage from sony handycam
By mtntrogger in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 11th Mar 2024, 00:30 -
Sony Video8 Handycam shows horizontal lines at bottom during playback
By Deichbruch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 15th Jan 2023, 12:35 -
Sony Handycam audio
By VideoGuyMark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Aug 2022, 21:40 -
Poor Video Quality in Digitized Sony Video8 Tapes (Video Attached)
By wsd33904 in forum Capturing and VCRReplies: 7Last Post: 16th Jan 2021, 19:47
