  1. Hello.
    I would appreciate if you could help me with programming a DVD.
    I have added a new audio to the DVD video, like this DVD, it only had one audio, the menu had no option to change the audio, so I added a pgc to give that menu option, I added another dummy pgc, to make the I jump from the audio button to the new pgc with the audio set up, but no matter how many changes I make, in the pgc created by me, when I press the audio button, it remains less than 1 second in the menu audio selection.
    I have changed the last line of the VTSM1 script, LU1 (ha), 8 dummy, to see if the instruction was not correct, but when I put LinkPGCN PGC3, LinkPGCN PGC4, LinkPGCN PGC6 in that line, it makes the jump correctly, so I put LinkPGCN PGC7, it goes less than 1 second and then black screen.
    I leave the information on the DVD commands.
    https://mega.nz/file/FVd0xCpb#wUeHqYCC6OY2aOohAtlxsUezfC25_LGtZFDPrq3cerI
    Greetings Lucho
  2. Solved thanks.
    Greetings Lucho
