Hi
a cat here,
however
please can you help me!?
I need to re-save (in batch mode) a single .jpg source to a .TGA file with alpha channel
I need to do the process via commandline so I need a suitable tool that do this via commandline
thanks
Try adding -rle 0
Code:Encoder targa [Truevision Targa image]: General capabilities: dr1 Threading capabilities: none Supported pixel formats: bgr24 bgra rgb555le gray pal8 targa AVOptions: -rle <int> E..V....... Use run-length compression (from 0 to 1) (default 1)
ffmpeg - alpha channel posterization
By iisperi in forum Video ConversionReplies: 21Last Post: 9th May 2024, 10:22 -
hex change the dwHeight value inside an .avi via commandline?
By marcorocchini in forum Newbie / General discussionsReplies: 11Last Post: 11th Aug 2023, 12:10 -
Vegas 13: replace black with transparent alpha?
By vegas13 in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2022, 12:15 -
SUB STATION ALPHA 4.08 - For 64 Bits Systems
By devilcoelhodog in forum SubtitleReplies: 6Last Post: 23rd Oct 2021, 13:51 -
VirtualDub -- “SAVE”, “SAVE AS”, “EXPORTING”, re-encoding
By Avagadro1 in forum EditingReplies: 2Last Post: 13th Aug 2020, 12:44
oh it works
