Hi, please help the cat
I need to generate a blurred background TGA image 16:9, HD resolution
How can I get it? thanks
Use GIMP (or any image editor you like), prepare background as you wish (i would resize image to 1920x1080 with distorted aspect and put on top source image resized to 1080 lines with proper aspect and apply to this Gaussian blur with radius accordingly to expected result after this i would export image as new background that can be used as second source to ffmpeg). This is best approach IMHO as i find performing similar steps in ffmpeg only inefficient.
oh my
[Attachment 84801 - Click to enlarge]
but I need to do this in batch
does exist a way to generate a BMP or TGA image, ready to use? one click mode?
at the moment I need to generate only a TGA from any source image file that is in any aspect ratio, my target is to get a blurred TGA backdrop of the source that realistically reflects the source and is 1920x1080 16:9 aspect ratio
clever FFmpeg-GUI, small FFmpeg UI, fully portable, no installation.
By ProWo in forum Video ConversionReplies: 3233Last Post: 10th Dec 2025, 16:40 -
Blurred background with text over it
By Hakunamatata67 in forum SubtitleReplies: 2Last Post: 17th Dec 2022, 05:34 -
how do i add libx264 and hevc to ffmpeg when i compile ffmpeg for ubuntu 21
By oduodui in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2021, 05:12 -
Get the complete FFmpeg command line when using FFmpeg Batch Converter
By pascor in forum Newbie / General discussionsReplies: 8Last Post: 14th May 2021, 00:14 -
[FFMPEG] Is there a way to remove this part that FFMPEG puts in the meta?
By GEOLINK in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2021, 18:51
