Hi im wanting to add my own custom animation to the beging of some vcd's so what is a good program to make animation with so i can do this.
Results 1 to 9 of 9
What kind of animation, 3D? go with Maya or 3D Studio Max.
Flash? Go with Macromedia Flash MX. -
If you want simple animated logos and the like, you can also go with a free GIF animator.
Ulead Cool3D is also a possibility.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Yeah i was kind of hoping to go for a animated cartoonish look i think maya might do the trick i will have to check it out.
Ok i went with animation shop three well i would have tried maya but i dont have enough ram.But heres my question on it how do you get your work to run smoothly becuse mine just keeps flashing between every animation.I am hoping to put this on some of my vcd's if it will run smoother.
A program that create transparent animation
By Cazz in forum EditingReplies: 11Last Post: 5th Jun 2011, 13:08 -
Anybody good at making title animation want some paid work?
By Mutt_CA in forum EditingReplies: 1Last Post: 16th Feb 2009, 22:29 -
whats a good program to use to convert/compress to h264
By cowboysroy31 in forum Video ConversionReplies: 1Last Post: 20th Jun 2007, 18:28 -
Whats the best DVD burning program out there?
By Tielurr in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2007, 18:21 -
Whats a good program to recover deleted files ?
By StoneColdWhat in forum ComputerReplies: 15Last Post: 23rd May 2007, 21:12
