I just learned today that Fox Sports will be carrying IndyCar racing this year. I thought not having Peacock involved would be good, but testing a replay rip is proving difficult.
I get 403: Forbidden when using the index.m3u8 link, I see no evidence of widevine involved and WideVineProxy2 doesn't seem to produce anything.
Any suggestions on how to get a usable link, key if needed, and blocking commercials if it's not automatic?
Results 1 to 14 of 14
Since these will be live streams, this is already what I do with football games on FS1:
Once broadcast starts, find the m3u8/index.m3u8 use the following:
Since this is a live stream, when done, hit "CTRL+C" to end. You will get an .ts file. From here yes, it will have ad segments, but you can edit those out however you'd want.Code:N_m3u8DL-RE --live-real-time-merge "***url of index.m3u8****" --save-name "Name of file"
I live rips better than replays? Honestly, ripping real-time streams frequently goes wrong for me (stupidity like starting too late, internet hiccups, etc.).
It also looks like they limit to 720p. :-\ -
They live stream in 720p60? Okay, that makes sense. You got me to check my cable broadcast and it's in that format. It makes sense.
You can try to grab what you want.
https://www.foxsports.com/replays
Edit: Still get an issues trying to rip. If I go for 7.m3u8 I get only the ads. If I use the index.m3u8 I get 403.Last edited by doctorm; 13th Jan 2025 at 18:44.
I got it working with streamlink and N_m3u8DL-RE
I chose replay https://www.foxsports.com/replay/fmc-059608rrac9jgvu4
For either option make sure to use the long weird url - proxy.1,proxy.2,proxy.3,proxy.4,proxy.5,proxy.6,pr oxy.7,proxy.8,proxy.9,proxy.10,proxy.11,proxy.12,p roxy.13.m3u8
streamlink
You can choose what option you want here, best gives you 720p 59.9 fpsCode:streamlink "hlsvariant://https://foxvideo-sports.akamaized.net/exp=1736907103~acl=%2f*~hmac=***************************************/vod//csm/builder/proxy.1,proxy.2,proxy.3,proxy.4,proxy.5,proxy.6,proxy.7,proxy.8,proxy.9,proxy.10,proxy.11,proxy.12,proxy.13.m3u8*******long****url********" --hls-segment-threads 5 -o PSU-USCWCBB2.ts [warnings][streamlinkdeprecation] `hls-segment-threads` has been deprecated in favor of the `stream-segment-threads` option [cli][info] Found matching plugin hls for URL hlsvariant://hlsvariant://https://foxvideo-sports.akamaized.net/exp=1736907103~acl=%2f*~hmac=***************************************/vod//csm/builder/proxy.1,proxy.2,proxy.3,proxy.4,proxy.5,proxy.6,proxy.7,proxy.8,proxy.9,proxy.10,proxy.11,proxy.12,proxy.13.m3u8*******long****url******** Available streams: 270p (worst), 360p, 480p, 540p, 720p_alt2, 720p_alt, 720p (best)
N_m3u8DL-RE
Depending on option here, also get 720p 59.9 fps.Code:N_m3u8DL-RE "https://foxvideo-sports.akamaized.net/exp=1736907103~acl=%2f*~hmac=***************************************/vod//csm/builder/proxy.1,proxy.2,proxy.3,proxy.4,proxy.5,proxy.6,proxy.7,proxy.8,proxy.9,proxy.10,proxy.11,proxy.12,proxy.13.m3u8*******long****url********" --save-name "PSUuscWCBB" 21:14:13.677 INFO : N_m3u8DL-RE (Beta version) 20230628 21:14:13.698 INFO : Loading URL:https://foxvideo-sports.akamaized.net/exp=1736907103~acl=%2f*~hmac=***************************************/vod//csm/builder/proxy.1,proxy.2,proxy.3,proxy.4,proxy.5,proxy.6,proxy.7,proxy.8,proxy.9,proxy.10,proxy.11,proxy.12,proxy.13.m3u8*******long****url******** 21:14:13.800 INFO : New version detected! v0.3.0-beta 21:14:13.846 INFO : Content Matched: HTTP Live Streaming 21:14:13.847 INFO : Parsing streams... 21:14:13.847 WARN : Master List detected, try parse all streams 21:14:13.854 WARN : Writing meta json 21:14:13.855 INFO : Extracted, there are 7 streams, with 7 basic streams, 0 audio streams, 0 subtitle streams 21:14:13.855 INFO : Vid 1280x720 | 6705 Kbps | 59.94 | avc1.640020,mp4a.40.2 21:14:13.856 INFO : Vid 1280x720 | 5385 Kbps | 59.94 | avc1.640020,mp4a.40.2 21:14:13.856 INFO : Vid 1280x720 | 4065 Kbps | 59.94 | avc1.640020,mp4a.40.2 21:14:13.857 INFO : Vid 960x540 | 2745 Kbps | 59.94 | avc1.4D4020,mp4a.40.2 21:14:13.857 INFO : Vid 852x480 | 1689 Kbps | 29.97 | avc1.4D401F,mp4a.40.2 21:14:13.857 INFO : Vid 640x360 | 897 Kbps | 29.97 | avc1.4D401E,mp4a.40.2 21:14:13.858 INFO : Vid 480x270 | 310 Kbps | 14.985 | avc1.4D4015,mp4a.40.5 21:14:16.181 INFO : Parsing streams... 21:14:16.692 INFO : Selected streams: 21:14:16.693 INFO : Vid *AES_128 1280x720 | 6705 Kbps | 59.94 | avc1.640020,mp4a.40.2 | 1494 Segments | ~01h38m56s 21:14:16.693 WARN : Writing meta json 21:14:16.698 INFO : Save Name: PSUuscWCBB 21:14:16.698 WARN : MuxAfterDone is detected, binary merging is automatically enabled 21:14:16.699 INFO : Start downloading...Vid 1280x720 | 6705 Kbps | 59.94 | avc1.640020,mp4a.40.2 21:14:17.039 WARN : Reading media info... 21:14:17.103 INFO : [0x1e1]: Video, h264 (High) ([27][0][0][0]), 1280x720, 59.94 fps 21:14:17.104 INFO : [0x1e2]: Audio, aac (LC) ([15][0][0][0]), 96 kb/s 21:14:17.105 INFO : [0x1e3]: Data, scte_35 21:14:17.106 INFO : [0x1e4]: Data, timed_id3 (ID3 ) 21:15:40.868 INFO : Binary merging... 21:16:29.480 WARN : PSUuscWCBB.ts
In both cases it does give you a .ts file. I just use ffmpeg to convert to mkv and all is working, in my example I get a full replay, no ads. Well there were no ads to start with on replay. But never tried before tonight, but works 100% both ways. -
I think the issue I'm running into is that the .m3u8 files links I get aren't similar. There's nothing with the proxy.1,proxy.2,...
Maybe you are ad blocking something I'm not or your cable provider gives you replays commercial free. I dunno. Also, when I click the replay you posted it says it isn't available from my cable provider.
I think I found something that I'm testing, but streamlink doesn't work with it and the download is slow. -
Yup. That was it. I had uBlock Origin disabled to avoid issues with stream ripping when ads are present. Enabling it changes the m3u8 to a downloadable stream.
n_m3u8dl-re makes for a fast and good process.
Thank you. That's going to be useful this year. -
A follow up question on this. While ripping these are pretty simple and there is no WideVine encryption, does Fox Sports have a DD5.1 audio track hidden somewhere (like for other devices) or is everything AAC 2.0?
Edit: What's weird is when I put the .m3u8 link into n_m3u8dl-re I'm given the option of the video resolution, but it says there is no audio track. Once it starts downloading, it gets the audio track as well... where is it finding the audio track if it's not in the playlist?Last edited by doctorm; 3rd Mar 2025 at 21:03.
The audio track is in the playlist, just not in a separate track. Here's an example
As you can see it has 2 codecs, for video and audio. They both come at once in the same track/file#EXT-X-STREAM-INF:BANDWIDTH=6090006,AVERAGE-BANDWIDTH=5358155,CODECS="avc1.64002a,mp4a.40.2",R ESOLUTION=1920x1080,FRAME-RATE=59.940--[----->+<]>.++++++++++++.---.--------.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Okay, I wouldn't have guessed mp4a was an audio codec, but I guess that makes sense. I checked a playlist and noticed that every stream version has 'mp4a.40.2', but the lowest resolution has
Does that make the 40.5 a different audio track (Edit: Tested and it seems to oddly be identical)? Still desperate to find a DD5.1. I've seen that the UK Fox Sports site seems to have it, I would expect us to somewhere as well.Code:#EXT-X-STREAM-INF:BANDWIDTH=399169,AVERAGE-BANDWIDTH=310180,CODECS="avc1.4D4015,mp4a.40.5",RESOLUTION=480x270,FRAME-RATE=14.985
Out of curiosity, can you give a uk fox sports video URL example that has dd5 ?
I don't have that. I've just seen videos from it posted on Reddit. I assumed it was Sky1, but the poster said Fox Sports.
How can I use a script to get a manifest.m3u8 file for Fox station feeds?
By Oldfart1234 in forum Video Streaming DownloadingReplies: 3Last Post: 15th Jan 2025, 13:31 -
Bally Sports Download Help
By CylonWolf in forum Video Streaming DownloadingReplies: 31Last Post: 31st Oct 2023, 12:30 -
Need help on downloading from sports.nhk.or.jp
By jgronwall in forum Video Streaming DownloadingReplies: 81Last Post: 25th Mar 2023, 00:57 -
Downloading Video From Fox Nation
By TheRandomOne in forum Video Streaming DownloadingReplies: 4Last Post: 17th Mar 2023, 13:10 -
Sports Editing Software
By gr8tnezz in forum Newbie / General discussionsReplies: 9Last Post: 8th Aug 2020, 00:51
