    Mar 2013
    Prague, CZ
    I have a file from YT in MPEG2-TS format. Before downloading (online watching), everything is OK, after the download, the sound and the image becomes asynchronous after a while - ie the sound is delayed by the image. At the end it is already 10 minutes. How can it be repaired or download without this shift? I used to do it a long time ago and it was quite a science. DEMUX, etc. Is there any elegant procedure? Or somehow a utility that will make it easier?
    Thanks for the advice
    Peter
  2. I have a file from YT in MPEG2-TS format.
    as far as I know youtube does not host transport streams, so something seems to be wrong with your download method.
    Mar 2013
    Prague, CZ
    correction: it's not YT but herohero video hosting...
  4. Post a mediainfo report (text mode) from this MPEG2-TS here.
    Mar 2013
    Prague, CZ
    here it is, after conversion to mp4. From ts, vhich is empty...
    ===================== General =====================
    Count : 322
    Countof stream of this kind : 1
    Kind of stream : General
    Stream identifier : 0
    Countof video streams : 1
    Countof audio streams : 1
    Video formats : AVC
    Video_Format_WithHint_List : AVC
    Codecs Video : AVC
    Audio formats : AAC
    Audio_Format_WithHint_List : AAC
    Audio codecs : AAC LC
    Complete name : C:\Users\Peter\Desktop\Příspěvek uživatele Cesty ke zdraví - Zd….mp4
    Folder name : C:\Users\Peter\Desktop
    File name : Příspěvek uživatele Cesty ke zdraví - Zd…
    File extension : mp4
    Format : MPEG-4
    Format : MPEG-4
    Format extensionsusually us : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
    Commercial name : MPEG-4
    Formatprofile : Base Media
    Internet media type : video/mp4
    Codec Id : isom
    Codec Id : isom (isom/iso2/avc1/mp41)
    Codec URL : http://www.apple.com/quicktime/download/standalone.html
    CodecID_Compatible : isom/iso2/avc1/mp41
    Codec : MPEG-4
    Codec : MPEG-4
    Codec extensionsusually use : mp4 m4v m4a m4b m4p 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma f4v
    File size : 333374009
    File size : 318 MB
    File size : 318 MB
    File size : 318 MB
    File size : 318 MB
    File size : 317.9 MB
    Duration (ms) : 1431994
    Duration (ms) : 23mn 51s
    Duration (ms) : 23mn 51s 994ms
    Duration (ms) : 00:23:51.994
    Duration (ms) : 00:24:06:20
    Duration (ms) : 00:23:51.994 (00:24:06:20)
    Overall bit rate mode : VBR
    Overall bit rate : 1862432
    Overall bit rate : 1 862 Kbps
    Frame rate : 29.312
    Frame rate : 29.312 fps
    Frame count : 41954
    Stream size : 1478264
    Stream size : 1.41 MB (0%)
    Stream size : 1 MB
    Stream size : 1.4 MB
    Stream size : 1.410 MB
    Proportion of this stream : 0.00443
    HeaderSize : 40
    DataSize : 331895753
    FooterSize : 1478216
    IsStreamable : No
    Title : Příspěvek uživatele Cesty ke zdraví - Zd…
    Movie name : Příspěvek uživatele Cesty ke zdraví - Zd…
    Performer : VideoProc Converter AI
    Genre : Video
    File creation date : UTC 2025-01-09 11:27:56.810
    File creation date (local) : 2025-01-09 12:27:56.810
    File last modification date : UTC 2025-01-09 11:28:19.854
    File last modification date : 2025-01-09 12:28:19.854
    Writing application : Lavf58.29.100
    Comment : Příspěvek uživatele Cesty ke zdraví - Zd…
    ===================== Video =====================
    Count : 334
    Kind of stream : Video
    StreamOrder : 0
    Format : AVC
    Format info : Advanced Video Codec
    Format URL : http://developers.videolan.org/x264.html
    Commercial name : AVC
    Formatprofile : Baseline@L3
    Formatsettings : 2 Ref Frames
    Formatsettings, CABAC : No
    Formatsettings, ReFrames : 2
    Formatsettings, ReFrames : 2 frames
    Internet media type : video/H264
    Codec Id : avc1
    Codec info : Advanced Video Coding
    Codec : AVC
    Codec : AVC
    Codec family : AVC
    Codec info : Advanced Video Codec
    Codec URL : http://developers.videolan.org/x264.html
    Codec/cc : avc1
    Codecprofile : Baseline@L3
    Codecsettings : 2 Ref Frames
    Codecsettings, CABAC : No
    RefFrames : 2
    Duration (ms) : 1431285
    Duration (ms) : 23mn 51s 285ms
    Duration (ms) : 00:23:51.285
    Duration (ms) : 00:23:51.285 (00:24:06:20)
    Bit rate : 1728107
    Bit rate : 1 728 Kbps
    Width : 1280
    Width : 1 280 pixels
    Height : 720
    Height : 720 pixels
    Sampled_Width : 1280
    Sampled_Height : 720
    Pixel aspect ratio : 1.000
    Display aspect ratio : 1.778
    Display aspect ratio : 16:9
    Rotation : 0.000
    Frame rate mode : VFR
    Frame rate mode : Variable
    Frame rate : 29.312
    Minimum frame rate : 0.453
    Minimum frame rate : 0.453 fps
    Maximum frame rate : 29.970
    Maximum frame rate : 29.970 fps
    Frame count : 41954
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8
    Bit depth : 8 bits
    Scan type : Progressive
    Interlacement : PPF
    Interlacement : Progressive
    Bits/(Pixel*Frame) : 0.064
    Stream size : 309177918
    Stream size : 295 MB (93%)
    Stream size : 294.9 MB
    Proportion of this stream : 0.92742
    Color range : Limited
    colour_description_present : Yes
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    ===================== Audio =====================
    Count : 272
    Kind of stream : Audio
    StreamOrder : 1
    Format : AAC
    Format info : Advanced Audio Codec
    Commercial name : AAC
    Formatprofile : LC
    Formatsettings, SBR : No (Explicit)
    Codec Id : 40
    Codec : AAC LC
    Codec : AAC LC
    Codec family : AAC
    Codec/cc : 40
    Duration (ms) : 00:23:35:36
    Duration (ms) : 00:23:51.994 (00:23:35:36)
    Bit rate mode : VBR
    Bit rate mode : Variable
    Bit rate : 128000
    Bit rate : 128 Kbps
    Channel(s) : 2
    Channel(s) : 2 channels
    Channel positions : 2/0/0
    ChannelLayout : L R
    Samples per frame : 1024
    Sampling rate : 44100
    Sampling rate : 44.1 KHz
    Samples count : 63150936
    Frame rate : 43.066
    Frame rate : 43.066 fps (1024 spf)
    Frame count : 60881
    Compression mode : Lossy
    Stream size : 22717827
    Stream size : 21.7 MB (7%)
    Stream size : 22 MB
    Stream size : 22 MB
    Stream size : 21.67 MB
    Proportion of this stream : 0.06815
    Default : Yes
    Default : Yes
    Alternate group : 1
    Alternate group : 1
  6. Post a mediainfo report (text mode) from this MPEG2-TS here.
    you might want to try again,..
