I wanna see the difference in quality between regular VHS and S-VHS. Does anyone know of any youtube videos, or videos on any other site, that would show it?
Results 1 to 30 of 69
Here's something on YouTube
https://m.youtube.com/watch?v=Vp-V9uNLqAQ -
That YT video is misleading, I will just copy/paste my comment I posted on that video 4 years ago to explain why:
No the difference is much more than what you have come to discover, Your mistakes are:
1- DVD is not the medium you want to use for this job, It's not about resolution, MPEG-2 compression is crappy plus youtube mp4 compression you have nothing left to show, You should capture lossless AVI 4:2:2 and, de-interlace with QTGMC, resize to 1440x1080 and upload to youtube.
2- You should use the same S-VHS VCR for both tapes and use S-Video out for both not composite.
That's what's called a fair comparison. -
i have lots of VHS tapes that i wanna digitize. i know S-VHS is the best VCR type to use. I just wanna see a visual example of the enhanced quality of using S-VHS compared to regular VHS.
Are the tapes you want to digitize actually recorded in S-video mode?
If they are, they most likely wont play properly in a regular (non s-video) machine
If not, you wont see the benefit the format offers in terms of the increased horizontal resolution.
You might see some slightly better (cleaner) picture when using the s-video cable due the y/c separation -
Yes, a non sense video. He is somehow comparing the 2 VCRs rather than the tapes and the standards. The same player should have been used .
Then you posted a wrong question because you want to see about different players (S-VHS and VHS) fed with the same standard VHS tape.
I do not find the link, but I remeber that here in videohelp forum or in digitalfaq forum there was an example of a capture of a VHS tape with a VHS VCR and later a capture of the same tape with a high end S-VHS with TBC and Y/C output, and the differences were evident (as you already know, accordingly to what you wrote). Try to do a search. -
Yes, but after processing a regular composite VCR combines the Y and C in one signal resulting in luma to chroma interference, The use of a Y-C capable (consumer S-Video) VCR skips that step.
Yes you can avoid the composite step by using a S-VHS deck, It's not that easy to modify an existing VHS recorder especially the newer ones, Everything is in the chip, Plus you can't take advantage of good mechanism and TBC used in high end S-VHS VCRs. If there is a better option outhere you think we haven't found it yet?
Good grief, did you bother to do any research before you posted?? A simple search on YouTube using "VHS vs S-VHS comparison" immediately turned up the original comparison which was prepared by JVC, the inventor of VHS and S-VHS:
JVC's S-VHS vs. VHS Official Comparison (1988 High Quality 60FPS Super VHS Demo Footage)
The comparison starts at the 2:50 mark. Make sure to turn up the quality to 1080p. -
Plenty of comments there that say "it wasn't worth it".
These days, in my limited experience with two SVHS machines, the condition of the machine is more important than whether it's VHS or SVHS. The problem, of course, is how you assess that. -
Turns out, that's not what the OP is asking for, If you keep reading the thread beyond the original post he wants to see the difference between a S-VHS machine and a regular VHS machine playing the same regular VHS tape, It's hard to do such comparaison with the age of the machines now, But given the fact a S-VHS machine provides separate Y and C, can have line TBC and the mechanism is usually of a high quality, regardless how little the visual difference is, it is still a winner.
Good question. You're not the first to have requested visual evidence and probably wont be the last. It seems claims and counter claims have been made for decades. You would have thought that the visual evidence would have also been freely available online for decades and the matter settled long ago.
Note that in the JVC video at no point does JVC claim that VHS tapes played on S-VHS machines will look better than on a VHS player. They dont answer that question.
It's the same in a few JVC S-VHS Owner's Manuals I've read online. In the manuals I've read, JVC states:
"● To make the most of the Super VHS picture performance we recommend that you use the supplied S-VIDEO cable to connect your VCR to a TV with an S-VIDEO input connector."
That was the obvious time for JVC to add "and this will also improve the playback quality of your VHS recorded tapes" That was their moment. But JVC said nothing. They missed their big chance to mention the added benefit, in multiple Owners' Manuals of their own new S-VHS machines. Make of that what you will.
s-video connections first made their appearance on higher definition formats such as S-VHS, Hi8, higher def Beta, DVD, and of course higher def digital formats like DV. Make of that what you will.
Also why apparently no manufacturer ever issued a separate VHS deck with s-video output is also puzzling. The only decks which did have the s-video output were combo units with a VHS deck plus a higher def format like DVD or Hi8 which formats did require s-video for full quality picture playback.
Would making good demonstrations of the difference be that hard even today? One good VHS machine and one good S-VHS machine?
Too difficult?Last edited by timtape; 14th Jan 2025 at 06:38.
Oh well, i recall how many people reacted violently few years ago when i proposed using RF capture to reconstruct magnetic recording - after few years seem this is fair approach in pursuing high quality magnetic tape capture...
So name that chip that prevent VCR modification to prevent Y and C mixing - i will be glad to confirm your point.
Side to this as you are quite long in this business then you know that it is the best to use for playout same recorder that was used in first place to made recording.
S-Video VCR are usually more expensive, less common especially nowadays. -
For example luma and chroma lowpass filters have usually a wider bandwidth for S-video players, so these filters would have to be touched as well when "upgrading" a VHS VCR to "S-VHS". Also the delay between luma and chroma will have to be re-aligned. Not straightforward and eventually still a compromise.
(On the negative an S-VHS VCR will not only recover more details from the VHS tape but also more noise.) -
JVC is in the marketing business, they wanted you to use S-VHS tapes not VHS tapes, so they don't need to make such a claim, though later in the years of VHS era they did come up with S-VHS ET to boost VHS tape sales, But JVC's goal of S-VHS recording and S-VHS tapes is to improve the luma bandwidth even when using composite, they know 90% of their customer base don't have a way to display S-Video, Sony in Beta didn't even bother to put a S-Video socket on almost all their Super Beta machines except one model I believe which is a US/Japan only.
Now in the capturing era we use such machines to bypass the composite stage which degrades the quality a bit especially chroma, and take advantage of line TBC/DNR, Whether someone sees the difference or not it all depends on how they do the test and how trained their eyes are, I certainly see the difference between composite and S-Video on the same S-VHS machine, let alone compared to a low end composite Funai VCR. -
do not forget anything - i just refereed to point where as one of main advances of the S-VHS over VHS was Y/S separated output - from my perspective this is second grade difference... so i just pointed that most of VHS VCR's can be easily modified to provide separated Y & C signal.
I agree that S-VHS has important advances over VHS - never claimed anything contrary to this.
You forget that S-VHS use different video heads and probably also different signal path to play VHS recordings...
How clever business man you are... so i put effort and knowledge and you will be the seller and you take profit (eventually generously split profit between you and me) but i take all risk... clever business model...Last edited by pandy; 14th Jan 2025 at 12:59.
You do realize that sounds stupid, I'll take it as you're ditching the original question.
LoL... hilarious - i had similar impression for your proposal... btw - there was no original question unless i should take seriously your "ice water bucket challenge" - i'm too old for such BS...
hahaha - good one - nope, obviously you have all "experience in the subject" so you probably not even now how to find Y & C signal in VCR...Last edited by pandy; 14th Jan 2025 at 18:48.
Then I dont understand why no company appears to have eventually made a VHS deck with S-Video output. It would have been attractive for customers because much cheaper than buying an S-VHS deck and they could play all their VHS tapes, past present and future, removing the claimed bottleneck of the composite output.
The problem with mere word based discussions like these is people reading dont get to SEE how much or how little a difference it makes. Like so many times before we have strayed away from the OP's perfectly legitimate and understandable request for visual examples and into mere text based arguments. As if the OP didnt even ask the question! Talking about pictures without showing those pictures. I find it very strange. The old saying is "a picture is worth 1000 words." Have we forgotten that? Give people the visual information to make the decision for themselves.Last edited by timtape; 14th Jan 2025 at 21:56.
JVC HR-S7600AM S-VHS VS. HM-DH5U D-VHS Capturing a VHS Tape
By dellsam34 in forum Capturing and VCRReplies: 26Last Post: 25th Aug 2023, 11:18 -
Can I use a regular VHS in a S-VHS camera?
By ceaselesswatcher in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2023, 04:17 -
Making SD music videos or found footage movies.. VHS, Super VHS or Hi8?
By part12studios in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2021, 09:57 -
Dual VHS/VHS-C VCRs to play VHS-C tapes wthout adapter
By Bsmarado in forum RestorationReplies: 7Last Post: 18th Mar 2021, 06:04 -
PAL VHS of American TV show. Does it need 'fixing'?
By robertzombie in forum RestorationReplies: 3Last Post: 27th Mar 2020, 02:04
