Hello,
I'm having trouble with ghosting. I've tried a bunch of options with various scripts.
Project is a composite of NTSC laserdisc & BD, so delivery will be 1080 24p.
Pay attention to Stewart's nose as he moves his head.
Current script I've got the best result is:
v= LWlibavVideoSource("side_1.mov",format="YUY2")
a= LWlibavAudioSource("side_1.mov")
AudioDub(v,a)
AssumeTFF()
QTGMC(preset="slow")
SelectEvery(5,2,4)
prefetch(8)
ColorMatrix(mode="rec.601->rec.709")
nnedi3_rpow2(2,cshift="Spline36Resize",fwidth=1920 ,fheight=1440)
Footage is 16mm, so I originally tried this script:
AudioDub(v,a)
TFM()
TDecimate(0)
prefetch(8)
Any ideas/changes in the script is much appreciated.
Hi davexnet. I tried that code and it is an improvement thank you. Looks like frames 16-18, 31-33 are still hairy.
Is there a way to adjust the script and see the instant results while the .avs is open in VirtualDub? or do you always have to reload the .avs?Last edited by clashradio; 12th Jan 2025 at 00:00.
It's F2 if the main VirtualDub2 window has the focus. If the script window has the focus it's F5. One of the annoying things about VirtualDub2.
It's F5 in AvsPmod. -
Thanks davexnet & jagabo for the VirtualDub help.
Am I stuck with this blending/ghosting? Is this baked in the video due to an improper IVTC? -
Probably.
More likely a frame rate conversion. Or multiple frame rate conversions. Maybe a temporal noise reduction filter too.
SRestore(frate=25.0) may work a little better. A long panning shot would be better for analyzing the correct frame rate. Also note that SRestore can take a while to lock into a pattern. So if you just scrub around the video and look at random frames you will see a lot more residual blending than if you step through a video frame by frame. -
Thanks jagabo. Looks like SRestore(frate=25) gives the best results. Problem is I converted the BD footage to 24p. The m2ts was originally 29.97 interlaced, which is confusing because they restored the 16mm footage for the 2022 BD, assumably from the negative which should be 24fps. I would think the BD should be 23.976.
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 03:01 -
How do I remove ghosting& screendoor/canvas effect from a DVD(cartoon show)
By dinoman in forum Newbie / General discussionsReplies: 15Last Post: 1st Nov 2021, 21:11 -
I have a DVD that needs IVTC but needs QTGMC for the credits.
By LaserBones in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2020, 19:26 -
Chroma Ghosting on AviSynth IVTC
By BruceKaneWayne in forum Video ConversionReplies: 3Last Post: 24th May 2020, 16:26 -
Deinterlacing & saving HD footage from pro cameras (QTGMC ffmpeg question)
By HighDeaf in forum Video ConversionReplies: 8Last Post: 23rd Mar 2020, 21:22
