Hi I have got a question if anyone can help me with it
Is there any websites were you can download instrument sounds like all the sounds a drum makes
And other instruments I have heard of softwares like flstudio were you can create you own music but it is quiet hard to use this software And some other softwares are also hard to create my own music. so I thought about if there was a website were you could download the instrument sounds and maybe on a pc and put them through a video converter software you would only get sound then but can that be done.
There is also a 2nd question I have
Is it possible to extract the instruments from a music software on a pc like a software like flstudio and other music softwares.
You install it on a pc would it be possible then to extract the instruments to WAV files which is a audio file
Then I could use it from a music game through my tv if it can be done.
Cos my music game you can add your own instruments but they have to be WAV files.
3rd question would be if it can be done
Is can you remove the vocals from a music video
And only keep the music with no vocals/words saying.
I know some people do this on YouTube so I know it can be done
But how what software would you use then
So If anyone can help with that.
Also is it possible to extract the instruments from a music video to a folder
All the instruments used in like a music video would it be possible to extract them separate with the vocals to a folder can that be done -
There are some works around this with AI - search for music decomposition , audio decomposition , music feature extraction , audio feature extraction .
question about extract subtitles from my satallite tv
By benhouli in forum SubtitleReplies: 41Last Post: 16th Feb 2024, 04:50 -
Get_iPlayer won't download BBC Sounds when setting the download directory
By VideoFanatic in forum Video Streaming DownloadingReplies: 5Last Post: 24th Jan 2024, 20:40 -
Download/Extract posterframe (thumbnail)
By Boldest06 in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2023, 13:30 -
I want to learn to download from all scripts, extract keys, create script
By M00MQ in forum Video Streaming DownloadingReplies: 5Last Post: 8th Jul 2022, 06:45 -
How to extract and use an m3u8 URL to download from a 24/7 stream?
By BosseB in forum Video Streaming DownloadingReplies: 28Last Post: 1st Feb 2022, 08:57
