It's only up for 24 hours https://www.bbc.co.uk/iplayer/episode/m0026p3j/breakfast-10012025 Please grab this in the best quality while stripping away any DRM. I'll be using N_m3u8DL-RE for this. Thank you.
Results 1 to 17 of 17
We all bleed blue from the inside....
Okay, thanks.
We all bleed blue from the inside.... -
if you need this, it 8.29GB
Code:http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_m0026p3h_3d93c0de-70ea-41b3-b41e-4a595a97d983.ism/hls/master.m3u8
Thank you. Can that code go in N_m3u8DL-RE, or should it be typed in differently?
Yes it can, any way you'd like using imaghosts url, example:
Code:N_m3u8DL-RE "http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_m0026p3h_3d93c0de-70ea-41b3-b41e-4a595a97d983.ism/hls/master.m3u8" --save-name "Breakfast - 10-01-2025" -M format=mkv
I get these errors:
D:\N_m3u8DL-RE>N_m3u8DL-RE "http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_m0026p3h_3d93c0de-70ea-41b3-b41e-4a595a97d983.ism/hls/master.m3u8" --save-name "Breakfast - 10-01-2025" -M format=mkv
16:04:07.779 INFO : N_m3u8DL-RE (Beta version) 20241201
16:04:07.820 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:11.617 WARN : Response status code does not indicate success: 403 (Forbidden). (1/10)
16:04:13.158 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:13.202 WARN : Response status code does not indicate success: 403 (Forbidden). (2/10)
16:04:14.698 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:14.738 WARN : Response status code does not indicate success: 403 (Forbidden). (3/10)
16:04:16.238 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:16.284 WARN : Response status code does not indicate success: 403 (Forbidden). (4/10)
16:04:17.777 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:17.812 WARN : Response status code does not indicate success: 403 (Forbidden). (5/10)
16:04:19.318 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:19.359 WARN : Response status code does not indicate success: 403 (Forbidden). (6/10)
16:04:20.859 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:20.896 WARN : Response status code does not indicate success: 403 (Forbidden). (7/10)
16:04:22.399 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:22.456 WARN : Response status code does not indicate success: 403 (Forbidden). (8/10)
16:04:23.956 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:24.020 WARN : Response status code does not indicate success: 403 (Forbidden). (9/10)
16:04:25.527 INFO : Loading URL: http://vod-hls-uk-live.akamaized.net/usp/auth/vod/piff_abr_full_hd/f8ae65-m0026p3h/vf_...ls/master.m3u8
16:04:25.564 WARN : Response status code does not indicate success: 403 (Forbidden). (10/10)
16:04:27.068 ERROR: Failed to execute action after 10 retries.We all bleed blue from the inside.... -
I can confirm this, and I still get the errors. I know the file's over 8 gigs, but worst case scenario please upload it to swisstransfer or some other platform. I want to get this before they remove it from the BBC.
I'm able to play it with a specific VPN, but I'm having difficulty determining which addon to install to grab the file. Video DownloadHelper fails to grab the file at at all.
I have downloaded said program but at 7.5 gb there is no way I will upload it.
I have two suggestions:-
1. You try the program I used to download (btw the highest available was 720p) - yt-dlp-gui
2. I am sure you do not want the whole 3+ hours of this magazine type program. If you fail to download it, point me to the sequence you want, which could be no more that 5 mins which is typical, and I will make that available tomorrow. -
Thank you so much! I was struggling for hours to get this file. Most appreciated!
Well it would have been good manners to, at the very least, thank me for my (unwanted) assistance - and I could never contemplate an upload of 7 gb due to slow upload connection.
I will now delete my download. And I respectfully suggest you actually learn how to do this yourself should the need arise in the future since I will not even contemplate helping again. And your 'friend' may not be around next time. -
iPlayer 4K Help
By SalAmi1 in forum Video Streaming DownloadingReplies: 8Last Post: 19th Nov 2025, 02:37 -
Download BBC iplayer video from abroad
By LolaZ in forum Video Streaming DownloadingReplies: 3Last Post: 26th Nov 2024, 15:32 -
Help / a favor to download a video "only works in the UK" (BBC iPlayer)
By Boldest06 in forum Video Streaming DownloadingReplies: 15Last Post: 28th Sep 2023, 04:20 -
video form bbc iplayer
By hansoljun in forum Video Streaming DownloadingReplies: 5Last Post: 20th Sep 2023, 11:40 -
Format of the bbc iPlayer video downloaded files
By fbmate in forum Video Streaming DownloadingReplies: 3Last Post: 9th Apr 2020, 06:23
