Hello, I'm new here, but I read and see a lot of knowledge here when it comes to the wonderful world of video and subtitles. maybe someone can help me. I'm trying to download a subtitle in english but it's kind of excrypted with AES-128. I would like to understand the steps to do this properly.
Can someone help me with that?
Link: https://hilalplay.com/en/watch/saladin-the-conqueror-of-jerusalem-s1-e21
Any help is greatly appreciated!
Results 1 to 13 of 13
Your subtitles:
https://www.swisstransfer.com/d/17258c47-b7fb-4b1d-96fe-8b9d2496ac35
Your video (1080p):
https://www.swisstransfer.com/d/053bbc69-f9a2-4057-961a-8f5e9d3d0b00--[----->+<]>.++++++++++++.---.--------.
[*drm mass downloader: widefrog*]~~~[*how to make your own mass downloader: guide*] -
Hi 2nHxWW6GkN1l916N3ayz8HQoi, can you explain how you decoded the subtitles? Thanks
I got the keys ... the response from https://content.hilalplay.com/v1/media/license.key?t=eyJhbGciOiJIUzUx.....
fIS/+hQqsdnYoj4d6LswfQ== [base64]
7c84bffa142ab1d9d8a23e1de8bb307d [hex] <== 32 digit key code
with the master m3u8
https://content.hilalplay.com/v1/media/master.m3u8?t=eyJhbGciOiJIUzUxMiJ9.e
Also, this m3u8 has max resolution 720p
#EXT-X-STREAM-INF:BANDWIDTH=3636569,AVERAGE-BANDWIDTH=2079035,CODECS="avc1.4d4028,mp4a.40.2",R ESOLUTION=1280x720,AUDIO="dubbed",SUBTITLES="subs"
/v1/media/720.m3u8?t=eyJhbGciOiJIUzUxMiJ9.eyJhcHAiOiI0LjEwLj IxIiwib
how did you get the 1080p m3u8?
Thanks -
2nHxWW6GkN1l916N3ayz8HQoi, thank you !! That's fast! Can you explain me how you decode the sub?
yt-dlp
Code:yt-dlp_x86 --write-subs --sub-langs all "https://content.hilalplay.com/v1/media/master.m3u8..." -o 1
Code:yt-dlp_x86 "https://content.hilalplay.com/v1/media/1080.m3u8..." -o 1.m2t
Use Tubedigger to download the subtitles.
There are several subtitles in the list the English is the third one to download.
See attached. -
Use stream detector addon, get the manifest m3u8 link, copy it as n_m3u8dl-re/yt-dlp command and run it in terminal. N_m3u8DL-re lets you choose manually what tracks you want (including subtitles), for yt-dlp you have to add other parameters that were already mentioned
This series was produced by TRT1. You can download all the episodes from the TRT1 website in 1080p with IDM
For Example EP21
https://www.trt1.com.tr/diziler/kudus-fatihi-selahaddin-eyyubi/bolum/21-bolum
There are many TV shows there.
Enjoy -
You can download 1080p without sound. You can then download sound only using yt-dlp (or download with video and then get rid of the lower quality video track). Then you can combine the 1080p video track with the audio track using mkvtoolnix.
how to decrypt vtt subtitle ?
By hatnaa in forum SubtitleReplies: 0Last Post: 15th May 2023, 08:30 -
Get VTT fragments in one vtt or srt file, MPD not m3u8
By maronsca in forum Video Streaming DownloadingReplies: 13Last Post: 27th Aug 2022, 11:02 -
By yassmine007 in forum SubtitleReplies: 6Last Post: 1st Oct 2021, 07:26 -
How to decrypt .vtt subtitle?
By yoons123 in forum SubtitleReplies: 3Last Post: 18th Sep 2021, 02:15 -
Help Decrypting VTT Subitile
By thegeek in forum SubtitleReplies: 2Last Post: 26th Apr 2021, 22:56
