now work fine. no error 403. this site is a mess! however thanks for your tip @lomero
Results 31 to 40 of 40
Good morning, my friends. The site has changed address now, it is streamingunity.co. I've modified a little cedric's script to adapt to this new site address, that is
import requests
import json
import re
import subprocess
from bs4 import BeautifulSoup
# Fonction pour récupérer l'URL m3u8
def get_ep(playerid, episodeId=None):
headers = {
'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36',
'Referer': 'https://vixcloud.co'
if episodeId:
params = {'episode_id': episodeId}
response = requests.get(f'https://streamingunity.co/iframe/{playerid}', headers=headers, params=params)
else:
response = requests.get(f'https://streamingunity.co/iframe/{playerid}', headers=headers)
soup = BeautifulSoup(response.text, 'html.parser')
iframe_tag = soup.find('iframe', {'ref': 'iframe'})
if iframe_tag:
iframe_src = iframe_tag.get('src')
response = requests.get(iframe_src, headers=headers)
# Récupération des informations nécessaires (URL, token, expires)
matches = {
'url': r"url: '([^']+)'",
'token': r"'token': '([^']+)'",
'expires': r"'expires': '([^']+)'"
m = {}
for match, regex in matches.items():
mm = re.search(regex, response.text)
if mm:
m[match] = mm.group(1)
else:
print(f"{match} not found")
if all(key in m for key in ['url', 'token', 'expires']):
m3u8_url = f"{m['url']}?token={m['token']}&expires={m['expires']}&h=1"
return m3u8_url
else:
print("Required keys are missing from the iframe response.")
return None
else:
print("No iframe tag found")
return None
# Fonction pour récupérer les saisons et épisodes
def get_season(page_url):
headers = {
response = requests.get(page_url, headers=headers)
app_div = soup.find('div', {'id': 'app'})
if app_div and 'data-page' in app_div.attrs:
data_page = app_div['data-page']
data_page_json = json.loads(data_page) # Utilisation de json.loads pour convertir en JSON
title = data_page_json['props']['title']['name']
playerid = data_page_json['props']['title']['id']
type = data_page_json['props']['title']['type']
if type == 'movie':
name_base = sanitize_filename(title)
m3u8_url = get_ep(playerid)
download_video(m3u8_url, name_base)
else:
season = data_page_json['props']['loadedSeason']
if season:
snumber = season['number']
for episode in season['episodes']:
enumber = episode['number']
name = episode['name']
episodeId = episode['id']
m3u8_url = get_ep(playerid, episodeId)
name_base = sanitize_filename(f"{title} S{str(snumber).zfill(2)}E{str(enumber).zfill(2)} {name}")
else:
print("No data-page attribute found in the div with id 'app'")
# Fonction pour nettoyer les noms de fichiers
def sanitize_filename(name):
return re.sub(r'[\\/*?:"<>|]', "", name)
# Fonction pour télécharger la vidéo avec N_m3u8DL-RE
def download_video(url, output_name_base):
output_file = f"{output_name_base}.mp4"
command = [
'N_m3u8DL-RE',
url,
'--header', 'User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36',
'--header', 'Referer: https://vixcloud.co',
'--save-name', output_name_base,
# '--tmp-dir', 'D:\',
# '--save-dir', 'D:\',
'-sv', 'best',
'-sa', 'all',
'-ss', 'all',
'-M' ,'format=mp4',
try:
subprocess.run(command, check=True)
print(f"Téléchargement et muxage terminé pour : {output_file}")
# except FileNotFoundError:
# print("N_m3u8DL-RE n'est pas installé ou n'est pas dans le PATH.")
except subprocess.CalledProcessError as e:
print(f"Erreur lors du téléchargement : {e}")
# Exemple d'URL à traiter
urls = [
"https://streamingunity.co/it/titles/6116-kindred"
for url in urls:
get_season(url)
The series to downloaded is Kindred. When I launch the script, anyway, I get the following error
No iframe tag found
File "D:\XXX\Winpython\WPy64-31241\python-3.12.4.amd64\cedric.py", line 122, in <module>
get_season(url)
File "D:\XXX\Winpython\WPy64-31241\python-3.12.4.amd64\cedric.py", line 82, in get_season
File "D:\XXX\Winpython\WPy64-31241\python-3.12.4.amd64\cedric.py", line 109, in download_video
File "D:\XXX\Winpython\WPy64-31241\python-3.12.4.amd64\Lib\subprocess.py", line 548, in run
with Popen(*popenargs, **kwargs) as process:
File "D:\XXX\Winpython\WPy64-31241\python-3.12.4.amd64\Lib\subprocess.py", line 1026, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "D:\XXX\Winpython\WPy64-31241\python-3.12.4.amd64\Lib\subprocess.py", line 1462, in _execute_child
args = list2cmdline(args)
File "D:\XXX\Winpython\WPy64-31241\python-3.12.4.amd64\Lib\subprocess.py", line 608, in list2cmdline
for arg in map(os.fsdecode, seq):
File "<frozen os>", line 859, in fsdecode
TypeError: expected str, bytes or os.PathLike object, not NoneType[/CODE] Moreover, I've noticed that links to videos are of the type https://vod-149347.vixcloud.co/embed/149347?token=dec1285a59cc356ae9526c6dbb52a08d&t=S...1&canPlayFHD=1, so it suggests maybe the row 'Referer': 'https://vixcloud.co' should be modified.
Any help? Thank you very, very much, in advance, for all kind and precious advices. Have a nice day -
not true. link is streamingcommunityz.cz
try to edit script with right link
anyway (not tested cedric script) this site it's easy to do: use stream detector plus to find right url, then download with N_m3u8DL-RE (or yt-dlp too) -
Thank you very much, lomero, for answer. Anyway, when I logged into site, I got a message telling to move to streamunity.co, as for registered used the page is more stable, so I moved to it. I've tested stream detector plus, but using either N_m3u8DL-RE or yt-dlp, I get a message of error 403 (forbidden) all the time.
i'm not registered user so idk. but link streamingcommunityz.cz work fine, also stream detector plus work on this url. so use this instead
also: if load streamunity.co into address bar, my browser go to https://www.hyperke.com/ ... are you sure this is your real link ??
[Attachment 88975 - Click to enlarge]
also i know that registered users are allowed to download the video. so if you are a registered user i don't understand your request here ... all very strange ... -
Thank you so much, lomero, for answer. I apologize very much, my mistake, the site is streamingunity.com. Fot what concerns registered users, I'm registered free user so I'm not allowed to download. I'm able to find m3u8 url, using chrome console, video download helper or the stream detector plus, too, anyway, downloading with N_m3u8DL-RE or yt-dlp I get a forbidden (403) error all the time, only cedric's script didn't always produce such error. The same problem arises if I use streamingcommunityz.cz
this is from streamingunity.com ....
[Attachment 88999 - Click to enlarge]
from streamingcommunityz.cz (now streamingcommunityz.at) work fine stream detect plus ext and RE -
This is what I get:
C:\Windows\system32>d:\biblioteca\N_m3u8DL-RE\N_m3u8DL-RE https://vod-149354.vixcloud.co/playlist/149354?type=subtitle&rendition=auto-forced&tok...sc-u2-01&scz=1 -M format=mp4 --tmp-dir "d:\WebDL\TVP" --save-dir "d:\WebDL\TVP" --save-name "prova"
09:25:43.150 INFO : N_m3u8DL-RE (Beta version) 20241201
09:25:43.260 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:44.176 WARN : Response status code does not indicate success: 403 (Forbidden). (1/10)
09:25:45.703 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:46.021 WARN : Response status code does not indicate success: 403 (Forbidden). (2/10)
09:25:47.538 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:47.831 WARN : Response status code does not indicate success: 403 (Forbidden). (3/10)
09:25:49.383 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:49.701 WARN : Response status code does not indicate success: 403 (Forbidden). (4/10)
09:25:51.217 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:51.408 WARN : Response status code does not indicate success: 403 (Forbidden). (5/10)
09:25:52.921 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:53.403 WARN : Response status code does not indicate success: 403 (Forbidden). (6/10)
09:25:54.904 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:55.153 WARN : Response status code does not indicate success: 403 (Forbidden). (7/10)
09:25:56.667 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:56.912 WARN : Response status code does not indicate success: 403 (Forbidden). (8/10)
09:25:58.418 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:25:58.638 WARN : Response status code does not indicate success: 403 (Forbidden). (9/10)
09:26:00.148 INFO : Loading URL: https://vod-149354.vixcloud.co/playlist/149354?type=subtitle
09:26:00.357 WARN : Response status code does not indicate success: 403 (Forbidden). (10/10)
09:26:01.942 ERROR: Failed to execute action after 10 retries.
'rendition' is not recognized as an internal or external command,
operable program or batch file.
'token' is not recognized as an internal or external command,
'expires' is not recognized as an internal or external command,
'edge' is not recognized as an internal or external command,
'scz' is not recognized as an internal or external command,
C:\Windows\system32> -
put plist link into ""
also wrong url. right is like this one:
https://vod-336867.vixcloud.co/playlist/336867?token=53ec8fb3e088d3cb69c686d3361199f2&...79&h=1&lang=it -
Thank you very, very much, lomero, for answer and precious advices. I've made as you said and i works. Thank you very much, again, for all your help. Have a nice day
Downloading an HLS stream: ONLY in sync when downloading with ffmpeg. Possi
By royjeon215 in forum Video Streaming DownloadingReplies: 6Last Post: 21st Jan 2024, 03:56 -
Help me downloading this :(
By Elias22 in forum Video Streaming DownloadingReplies: 1Last Post: 4th Jan 2023, 12:59 -
Help downloading TS
By dzigelbaum in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Dec 2022, 05:08 -
Need Help Downloading this
By daigo99 in forum Video Streaming DownloadingReplies: 16Last Post: 20th Jul 2021, 19:58 -
Downloading From FS
By Abraham in forum Video Streaming DownloadingReplies: 1Last Post: 29th Jul 2020, 05:39
