i have several videos of resolution 1920 x 1088.
My Sony HD LED TV can only play videos of maximum resolution 1920 x 1080.
so, i want to downscale them to 1920 x 1080.
Without loosing video quality.
Can expert help me for this in FFmpeg or in other tools?
Update:
I am able to downscale video by these tips, one more thing 1920 x1088 is also working in Sony Led TV.
Issue was due to file corruption. I copied file from laptop again in USB, now it works..
Thanks to All.
Results 1 to 14 of 14
How come your files are 1920 x 1088, that seems rather strange ?
I am sure that one of the experts in here can help better than i can. -
1088 is the internal mod16 padded size, used by the encoder. Usually it is cropped to 1080. If it is really 1088 and the player refuses to play it one can just crop it to 1080.
In ffmpeg you can try something like
Code:ffmpeg -i "your_source" -c:a copy -c:v libx264 -preset slow -crf 20 -pix_fmt yuv420p -vf "crop=1920:1080:0:0" "cropped.mp4"
@dc7800
you mentioned "several videos" ..
try:
Best Video Converter
it is a bit outdated but it uses FFmpeg (hint: update FFmpeg binaries, if needed), and allows for batch conversion and supports multiple CPU cores, MMX / SSE instructions and GPU acceleration.
Another method will be to try lossless crop using Clever FFmpeg assuming your Sony TV supports it.
@ProWo
It is not in fact necessary to re-encode, if the player you use supports crop parameter in the video bitstream (x264, hevc).
ffmpeg -i "input.mp4" -codec copy -bsf:v h264_metadata=crop_top=128 "output_cropped.mp4"
this will crop 128 pixels from the top of a mp4/x264 video, if the player supports the video bitstream tag.
(for x265: hevc_metadata=crop_top=128)Last edited by videoAI; 4th Feb 2025 at 22:14.
If it's h.264 or h.265 video it's possible to set the codec's internal cropping values without re-encoding (codecs often work in mod 16 frame sizes internally, then crop to the desired frame size for output). Since there's no re-encoding it's very fast and there is no quality loss (aside from the pixels that are cropped away).
See: https://www.videohelp.com/software/H264infoLast edited by jagabo; 8th Jan 2025 at 10:37.
Shutter Encoder and HandBrake are free programs. There is no noticeable difference in video quality.
ffmpeg can modify the h.264 flags too. See the bitream filter's h.264 and h.265 metadata's crop_arguments:
https://ffmpeg.org/ffmpeg-bitstream-filters.html#h264_005fmetadata
https://ffmpeg.org/ffmpeg-bitstream-filters.html#hevc_005fmetadata
Something like:
You might also need to specify the aspect ratio and the frame sized flagged at the container level. Like with h264info, this method is lossless.Code:ffmpeg -i 1088.mov -c copy -bsf:v h264_metadata=crop_bottom=8 1080.mov
Those are good answers.
To address the side issue of "WILL DOWNSCALING VIDEO LOSE QUALITY?", the answer is YES, it always loses quality. How much & how noticeable vary, depending on size ratios, settings, resulting codec, settings & bitrate, scaling algorithm, your sensitivity, etc.
Scott -
Please check
General
Complete name : 2.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 1.96 GiB
Duration : 23 min 1 s
Overall bit rate : 12.2 Mb/s
Writing application : Lavf57.83.100
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 4 frames
Codec ID : avc1
Bit rate : 12.0 Mb/s
Width : 1 920 pixels
Height : 1 088 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.239
Stream size : 1.93 GiB (98%)
Writing library : x264 core 138
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=48 / keyint_min=4 / scenecut=0 / intra_refresh=0 / rc_lookahead=48 / rc=abr / mbtree=1 / bitrate=12000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=16800 / vbv_bufsize=24000 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 192 kb/s
Maximum bit rate : 195 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 31.6 MiB (2%)
Default : Yes
Alternate group : 1
If you're looking for a simple way to downscale videos without quality loss, FFmpeg is a great choice. Using the command below, you can crop the video to 1920x1080 without re-encoding, ensuring no quality loss:
ffmpeg -i "input.mp4" -c copy -bsf:v h264_metadata=crop_bottom=8 "output.mp4"
This method is fast and maintains the original quality. For detailed tasks, you can also try tools like HandBrake or Shutter Encoder.
downscale 1080p to 720p with good quality using NVIDIA CUDA
By SmurfRecorder in forum Video ConversionReplies: 6Last Post: 19th Dec 2024, 13:33 -
convert HEVC video to H.264 mp4 without loosing quality
By jimclark in forum Video ConversionReplies: 8Last Post: 20th Mar 2024, 15:38 -
AVC editor without loosing quality
By tad108 in forum EditingReplies: 0Last Post: 13th Aug 2023, 08:18 -
Merging 3D MTS videos without loosing the 3D and the overall quality
By DashInc in forum EditingReplies: 16Last Post: 15th Oct 2021, 03:21 -
Upscale and downscale = better quality?
By Quantumleap in forum Video ConversionReplies: 5Last Post: 4th Apr 2021, 02:16
