Joyn has not been able to be downloaded via StreamFab for weeks now, just nothing gets analyzed. Anything I can do, either with SF or another tool ? Can be tested on joyn.de with free videos.
alright, widefrog not provide joyn but plus.rtl.de
then try widevine proxy2 browser extension.Last edited by shellcmd; 7th Jan 2025 at 00:34.
Did SF work reliably for joyn anyway? AFAICT nothing has changed on joyn for months. As @shellcmd suggests: try the WidevineProxy2 browser extension. You'll find it in the stickies in this forum, as well as a ready to use CDM you'll need.
Thanks, I installed it and downloaded some of those CDMs. Unfortunately, they appear to be for a different version ? The extension is looking for them in a .json format, but the downloads from the CDM thread are in .bin/.pem for the first link collection, and .wvd for the second. Could not find any .json files anywhere.
I did, it shows keys, but no `N_m3u8DL-RE` command line I could use. Any idea how to proceed ? Edit: nm I found it seconds after posting *♂️
I've successfully downloaded a few episodes, though it sure is a lot more tedious like this than just clicking a show and having a hundred eps queued up. SF used to work perfectly fine for Joyn until a month or two ago, and I think the problem isn't the decrypting itself, it's the analyzing - it tries to play the show instead of analyzing and prompting the ep/settings selection dialogue. They changed the status of Joyn from broken to fixed about two weeks (and updates) ago, so I was thinking maybe there was some issue with cache files or something similar where I had to reset or wipe something.
Joyn.at
By la1808 in forum Video Streaming DownloadingReplies: 11Last Post: 1st Feb 2025, 08:39 -
How can i decrypt a stream from Joyn?
By PyNoob in forum Video Streaming DownloadingReplies: 7Last Post: 29th Jan 2025, 04:48 -
Can’t download anymore from Joyn with Streamfab
By phonkilla26 in forum Video Streaming DownloadingReplies: 8Last Post: 29th Aug 2024, 13:50 -
Download from joyn.at
By mcdy in forum Video Streaming DownloadingReplies: 13Last Post: 17th May 2024, 15:16 -
Joyn
By Bugs Bunny in forum Video Streaming DownloadingReplies: 3Last Post: 24th Jan 2024, 15:34
