  1. I'm seeking advice on restoring digital video recorded with a Nokia camera phone (y 2005 model). I've included a short test clip featuring friendly kittens. This video was recorded using the highest quality settings available on the device.
    I understand that restoring footage from such a source can be challenging. I would be grateful for any recommendations regarding workflows.
    Thank you in advance.
    MI:
    General
    Complete name : /media/oem/PvzUSBback2023Rgs18/Video006.3gp
    Format : MPEG-4
    Format profile : 3GPP Media Release 5
    Codec ID : 3gp5 (3gp5/3gp4/3g2a/isom)
    File size : 459 KiB
    Duration : 49 s 840 ms
    Overall bit rate : 75.4 kb/s
    Frame rate : 13.819 FPS
    Encoded date : 2008-11-30 09:29:49 UTC
    Tagged date : 2008-11-30 09:29:49 UTC
    Video
    Format : H.263
    Format profile : BaseLine@1.0
    Codec ID : s263
    Duration : 49 s 642 ms
    Bit rate : 61.4 kb/s
    Width : 176 pixels
    Height : 144 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Minimum frame rate : 3.802 FPS
    Maximum frame rate : 18.529 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.175
    Stream size : 372 KiB (81%)
    Writing library : Nokia
    Language : English
    Audio
    Format : AMR
    Format/Info : Adaptive Multi-Rate
    Format profile : Narrow band
    Codec ID : samr
    Bit rate mode : Constant
    Bit rate : 12.8 kb/s
    Channel(s) : 1 channel
    Sampling rate : 8 000 Hz
    Bit depth : 13 bits
    Stream size : 77.9 KiB (17%)
    Language : English
  2. I'd say it's hopeless - aside from smoothing ugly blockyness, little can be done here:
  3. I did this for an early 1990s digital video. I have also done it for early flip phone cell video. Here's a thread I started that describes what I did:
    Ideas for restoring early generation (really old) digital video
    Even though my old post is fourteen years old, all the links still work, so you can see the original, and then look at the result I posted on YouTube. If you have time, watch the wonderful performance by the late Geoffrey Lewis (used to be on "Rawhide" with Clint Eastwood, and was in lots of his movies).
  4. Capturing Memories dellsam34's Avatar
    Jan 2016
    Like they say, You can't make chicken salad out of chicken $hit, And I don't mean just the low resolution and the primitive compression, the shooting skills are zero to begin with, a shaky footage makes the compression algorithms go nuts even the very modern ones, I hope you get something out of it.
  5. not worth the effort
    users currently on my ignore list: deadrats, Stears555
