Good morning. Can you please grab https://filmio.hu/film/az-erdo-kapitanya-12656361 in its highest quality (MKV) while removing the DRM? I plan to use N_m3u8DL-RE for this. Thanks.
We all bleed blue from the inside....
N_m3u8DL-RE "https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4/2022/04/23/12656361/index.json/manifest.mpd" --key 6761374a7eb04b59a595a943f4dbcdbe:ed38695f26825877db9b0335f2212bb9 -M format=mkv
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
After 10 attempts, I get these errors:
D:\N_m3u8DL-RE>N_m3u8DL-RE "https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4/2022/04/23/12656361/index.json/manifest.mpd" --key 6761374a7eb04b59a595a943f4dbcdbe:ed38695f26825877d b9b0335f2212bb9 -M format=mkv
04:03:02.869 INFO : N_m3u8DL-RE (Beta version) 20241201
04:03:02.886 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:03.560 WARN : Response status code does not indicate success: 404 (Not Found). (1/10)
04:03:05.059 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:05.391 WARN : Response status code does not indicate success: 404 (Not Found). (2/10)
04:03:06.898 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:07.336 WARN : Response status code does not indicate success: 404 (Not Found). (3/10)
04:03:08.830 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:09.171 WARN : Response status code does not indicate success: 404 (Not Found). (4/10)
04:03:10.669 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:10.991 WARN : Response status code does not indicate success: 404 (Not Found). (5/10)
04:03:12.492 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:12.935 WARN : Response status code does not indicate success: 404 (Not Found). (6/10)
04:03:14.441 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:14.895 WARN : Response status code does not indicate success: 404 (Not Found). (7/10)
04:03:16.390 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:16.829 WARN : Response status code does not indicate success: 404 (Not Found). (8/10)
04:03:18.338 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:18.816 WARN : Response status code does not indicate success: 404 (Not Found). (9/10)
04:03:20.318 INFO : Loading URL: https://c401-node62-cdn.connectmedia.hu/6112/9564a94fe3c5fff11015654e96735617/677b94d4...n/manifest.mpd
04:03:20.765 WARN : Response status code does not indicate success: 404 (Not Found). (10/10)
04:03:22.266 ERROR: Failed to execute action after 10 retries.Last edited by Lupine Assassin; 6th Jan 2025 at 04:03.
We all bleed blue from the inside.... -
Weird, it worked fine for me
https://www.swisstransfer.com/d/39c7909c-21a7-43c2-8e4e-0b6ff63b11c5--[----->+<]>.++++++++++++.---.--------.
Thanks for uploading it to swisstransfer, I appreciate it. I put your code in exactly as you typed it and I got those errors.
Same problem for me.
So, get a fresh mpd link and launch the command.
You can also install Stream Detector Addon to get the mpd link directly.
Need Help for downloading this one please
By monks19 in forum Video Streaming DownloadingReplies: 2Last Post: 22nd May 2024, 04:30 -
Downloading an HLS stream: ONLY in sync when downloading with ffmpeg. Possi
By royjeon215 in forum Video Streaming DownloadingReplies: 6Last Post: 21st Jan 2024, 03:56 -
By talms in forum Video Streaming DownloadingReplies: 8Last Post: 27th Jan 2023, 07:04 -
Help me downloading this :(
By Elias22 in forum Video Streaming DownloadingReplies: 1Last Post: 4th Jan 2023, 12:59 -
Need Help Downloading this
By daigo99 in forum Video Streaming DownloadingReplies: 16Last Post: 20th Jul 2021, 19:58
