Have always found Win10 very difficult for audio (compared to XP)
Wanted to help someone set up a USB turntable. But as soon as the USB cable was connected, all sound died.
Unlplug and sound came back.
So then tried Line Input on the Sound Card. The Sound properties for Recording showed Line In Selected and a wee green LED indicated it could hear it. But no way would it play through the speakers.
Device manager showed no problems and the required Codec was installed.
The Sound Mixer has 3 faders, but no "line in" assuming it should. Sound plays fine from Winamp or via the net, YouTube etc.
Any help appreciated! Or an email address for Audio Technica. Model is AT120USB.
Results 1 to 10 of 10
I would connect it to a stero or other device with a line-in and confirm the turntable is putting out the correct
line-out signal. Their info says that it should have such a thing, since it doesn't require the device to have a dedicated
phono input
"But in addition to the USB output, the turntable also comes with a detachable dual RCA output cable and is equipped with a built-in selectable phono preamp so you can connect directly to your home stereo, whether it has a dedicated phono input or not."
Support email here:
customerservice@support.atus.comLast edited by davexnet; 5th Jan 2025 at 22:05.
Yes, we could use the RCA leads into an amp, but nothing heard on the comp.
Thanks for link.. will get intouch. -
Yes, as mentioned - where the green meter was showing a signal. It got that far.
No, there was not, unless it was one of the 3. I think they were Speakers, System and Thunderbird.
Computer is not here, at a friends place.
MAGIX analogue capture device problem on Win 10
By OldTech in forum Capturing and VCRReplies: 28Last Post: 12th Dec 2022, 14:39 -
Color problem when playing movie on win 10
By DragonChasm in forum Software PlayingReplies: 2Last Post: 15th Nov 2021, 09:39 -
Win XP: Route audio input of soundcard to speakers of same soundcard
By sdsumike619 in forum ComputerReplies: 13Last Post: 16th Sep 2021, 16:54 -
Audio sync problem - can you please tell me where the problem is ?
By Jose Hidalgo in forum AudioReplies: 7Last Post: 5th Jun 2020, 16:07 -
Win 10 waking from sleep causes OC problem
By sdsumike619 in forum ComputerReplies: 5Last Post: 26th Feb 2020, 15:55
