This one's driving me crazy.
I made an AVI, which is all in sync, the whole time. I used MP3 compression at 22kHz and when I convert to MPEG, the audio is slightly slower than the video. It starts out in sync, but slowly drags behind. Any of the sync fixes I have seen assume it's all lined up together, just offset by a few ms.
I tried extracting the sound with VirtualDub (save as Wav) but when I encode from the two different sources the same thing happens.
Any way I can fix this? Capturing it all over again would be a pain, and I wouldn't know if I fixed it until I got way late in the game anyways.
At what frame per minute did you capture the avi file ??
Best captures are 29.97 for NTSC and 25 for PAL/SECAM.
Don't bother capturing at other settings cos your audio will be f**ked and picture will be choppy. -
I recorded at 29.97 fps. Unfortunately the default was 320x240 so I didn't quite get the right screen size.
I used Indeo 5, and the encoding was solid enough so I got average 30 fps while running. -
when you convert to mpeg do you also encode at 29.97fps cos if not that could be your problem
Yes, I've tried TMPGenc, with the default templates and with "unlocked" tweaking.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
another audio sync question (mkv)
By ginahoy in forum AudioReplies: 4Last Post: 14th Mar 2012, 22:03 -
Nero Recode 2 Chapter Mark "Creep" vs. Original DVD
By CobraPilot in forum DVD RippingReplies: 4Last Post: 16th Feb 2012, 22:29 -
Another Audio sync question....
By defiantclass1 in forum AudioReplies: 8Last Post: 24th Aug 2011, 12:22 -
Video/Audio Sync Question
By MegaTonTerror in forum Video ConversionReplies: 29Last Post: 27th Jul 2009, 06:18
