Hi all,
I'd really appreciate any feedback on the attached 10 second sample clip. I've learned a lot on how to use AviSynth+ and Hybrid these last few weeks, although for me personally, some of the input language for creating scripts is difficult for me to completely wrap my head around. This particular video has a good deal of motion, and I've tinkered with the script for this video dozens of times to compare outputs. I just don't have the eye to determine its true quality and was hoping for guidance on where I can possibly make improvements?
I'm including the raw capture .avi file, the edited .avi file after using AviSynth+, and the final .mp4 output using Hybrid. I'm still very much a novice (and thus have a great deal of respect for you all who know what you're doing given the hours I've put in), but I haven't see much of a difference in quality after testing lines for a denoiser/degrainer in the script (notably TemporalDegrain2 & MCTemporalDenoise, although the latter only works for me if I include "fixband=false" - which I learned from an older thread on this site). If anyone could give me some pointers or their opinion, I'd be very grateful.
The script I used for the attached video:
AVISource("D:\Source File.avi")
ConvertToYV12()
AssumeTFF()
chubbyrain2()
smoothuv2(radius=7)
QTGMC(preset="fast",TR2=2)
LSFmod(strength=100, Smode=3, Smethod=2, kernel=11)
Stab()
Spline64Resize(640,480)
Prefetch(7)
Thank you - I really do appreciate your guidance. (Side note, I know I still need to crop)
Aside from ConvertToYV12:
- ChubbyRain2() needs to be called with 'interlaced=true' or moved behind the deinterlacer.
- Smoothuv2 needs to be called with 'interlaced=1' or moved behind the deinterlacer.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Avisynth sharpening filters in Hybrid for vhs capture?
By Leanoric in forum RestorationReplies: 77Last Post: 22nd Feb 2024, 04:53 -
AVISynth- "Requesting Info on "Clang"
By Alwyn in forum ProgrammingReplies: 5Last Post: 1st Dec 2023, 13:31 -
RealCUGAN in hybrid vs Waifu 2x Extension Gui (slow in hybrid)
By Platos in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2023, 05:43 -
Selur Hybrid: how to export profile and/or AVS script
By Darryl In Canada in forum RestorationReplies: 1Last Post: 7th Feb 2022, 11:11 -
Can AviSynth+ script be loaded into Hybrid?
By VideoDoc in forum RestorationReplies: 2Last Post: 9th Oct 2021, 09:27
